Flavien21
ID3 – Version logiciel
Le message du 16/12/2022 :
Citation
Dear all,
The rollout of the next ID. software 3.0 OTA-wave will start this week. Please note that the rollout will take some time. Within the next few days, you will receive a confirmation via email as soon as your ID. is ready to receive the update.
As promised, and based on your feedback, please find a few helpful tips & tricks for an easier installation process below.
Once you have received the notification in the infotainment system that a new software update is available, please keep in mind the following tips:
1. Ensure a minimum SOC (State of Charge) of at least 50 % when parking your ID.
2. A stable mobile connection (at least 2 bars, 4G) must be established at the beginning of your trip and when parking your car.
3. The charging cable must not be plugged in before and during the installation process.
4. Your ID. must be “enrolled” (linked to your We Connect account via the We Connect ID. app) at any time.
5. In case you receive the notification “Software update available” in the infotainment system but the installation button does not appear, please check again if all previous tips have been considered. If so, you can trigger the installation button to appear by following these steps:
  • Leave and lock the car for at least 15 minutes with the keys out of the car's reach. Then go back to the car.
  • After entering the car, do not press the brake pedal. Instead, please wait at least 90 seconds before turning on the ignition using the ignition button behind the steering wheel.
  • Then wait again for at least 90 seconds before turning off the ignition.
  • You should now find the "update available" button in the exit panel.
6. If your ID. tells you to close all windows, please follow these steps:
  • Open all windows.
  • Now close one window after another. Each time a window is closed, shortly release and then pull again the window switch.
These tips & tricks will continue to be expanded over time thanks to your feedback. Thank you!
Our updates are designed in a way where you as the owner decide when to start the installation. Please remember that due to the holiday season, roadside assistance may be limited, so please keep that in mind when choosing a time slot for the installation.
Best regards,
Your Volkswagen ID. team
et la traduction automatique :
Citation
Chers tous,
Le déploiement du prochain identifiant. Le logiciel 3.0 OTA-wave débutera cette semaine. Veuillez noter que le déploiement prendra du temps. Dans les prochains jours, vous recevrez une confirmation par e-mail dès votre pièce d'identité. est prêt à recevoir la mise à jour.
Comme promis, et en fonction de vos commentaires, veuillez trouver ci-dessous quelques conseils et astuces utiles pour un processus d'installation plus facile.
Une fois que vous avez reçu la notification dans le système d'infotainment qu'une nouvelle mise à jour du logiciel est disponible, veuillez garder à l'esprit les conseils suivants :
1. Assurez-vous d'un SOC (état de charge) minimum d'au moins 50 % lors du stationnement de votre pièce d'identité.
2. Une connexion mobile stable (au moins 2 bars, 4G) doit être établie au début de votre voyage et lors du stationnement de votre voiture.
3. Le câble de recharge ne doit pas être branché avant et pendant le processus d'installation.
4. Votre carte d'identité. doit être «enrôlé» (lié à votre compte We Connect via l'ID We Connecte. application) à tout moment.
5. Au cas où vous recevrez la notification « mise à jour logiciel disponible » dans le système d'infotainment mais que le bouton d'installation n'apparaît pas, veuillez vérifier à nouveau si tous les conseils précédents ont été pris en compte. Si oui, vous pouvez déclencher l'affichage du bouton d'installation en suivant ces étapes :
Laissez et verrouillez la voiture pendant au moins 15 minutes avec les clés hors de portée de la voiture. Alors retourne à la voiture.
Après être entré dans la voiture, n'appuyez pas sur la pédale de frein. Veuillez plutôt attendre au moins 90 secondes avant d'allumer le contact en utilisant le bouton d'allumage derrière le volant.
Ensuite, attendez à nouveau pendant au moins 90 secondes avant d'éteindre le contact.
Vous devriez maintenant trouver le bouton "mise à jour disponible" dans le panneau de sortie.
6. Si votre pièce d'identité. vous dit de fermer toutes les fenêtres, veuillez suivre ces étapes :
Ouvre toutes les fenêtres.
Maintenant fermez une fenêtre après l'autre. Chaque fois qu'une fenêtre est fermée, relâchez bientôt et tirez à nouveau sur l'interrupteur de fenêtre.
Ces conseils & astuces continueront à être étendus au fil du temps grâce à vos commentaires. Merci!
Nos mises à jour sont conçues de manière à ce que vous, en tant que propriétaire, décidez quand commencer l'installation. N'oubliez pas qu'en raison de la saison des fêtes, l'assistance routière peut être limitée, donc n'oubliez pas cela lorsque vous choisissez un créneau horaire pour l'installation.
Meilleures salutations,
Votre identifiant Volkswagen. l'équipe
Le 16/12/2022 à 12:11, Litaire a dit :
Comment faire compliqué quand d’autre savent faire…
🤯 super le coup des vitres !
Pour la 4.0 il faudra peut-être allumer 2 fois les warnings pendant 6 secondes et ensuite chaque feu clignotant 3 fois ?…
Quand j'avais fait la mise à jour 2.4, j'avais perdu l'ouverture/fermeture depuis la télécommande, c'est ce genre de manip que j'ai fait pour retrouver la fonctionnalité. Mais c'est vrai que lorsqu'on lit qu'il faut monter dans la voiture, attendre 90s puis appuyer sur le bouton mais pas sur la pédale... 😮.
Ça me rappelle les débuts du PC ou on avait le message "Aucun clavier détecté, appuyez sur F1 pour continuer" 🤣
Modifié par Tiberius
Le 16/12/2022 à 14:34, AlexaRom a dit :
Fichtre.
ça sera pour 2024 alors
Si tu es sur FaceBook dans le groupe officiel. Rien t’empêche de faire la demande directement à Volkswagen ID via Messenger.
Peut être qu'il accepterons ton e-mail en retard, mais c'est surement trop tard pour la deuxième vagues.
Pour les autres qui on pas facebook envoyé des mail à la relation client chez Volkswagen avec votre VIN il devrait pouvoir vous dire si vous êtes prévu bientôt ou pas en fonction du modèle de voiture.
Et si vous demandez rien car vous êtes pas presser, vous recevrais un mail comme pour la 2.4 vous informant de la mise à jour par les airs prochainement. Via l’e-mail que vous avez renseigné sur l'application WeConnectID
Modifié par ID.3
Le 16/12/2022 à 10:50, Cavogrenier a dit :
Nouveau post officiel sur Facebook pour la 3.0 (pour la 2e vague du "I want OTA 3.0") :
https://www.facebook.com/groups/volkswageniddriversclub/posts/1083212582355087/
Et mail reçu presque dans la foulée.
Ce fil parle du déploiement de la version 3.0 "tout court". Il ne s'agit pas du déploiement destiné à ceux qui avaient demandé la mise à jour par anticipation via le post sur le groupe facebook.
Le 16/12/2022 à 19:53, Man's a dit :
Merci beaucoup !
Pas besoin de mettre le VIN ou un autre identifiant du véhicule ?
Si c'est mieux avec le VIN avec la même adresse mail du compte weconnectID
Modifié par ID.3
Le 17/12/2022 à 09:03, Xeoth a dit :
J'ai également reçu le mail hier.
Pour ceux qui sont en 3.0, la programmation de charge fonctionne de nouveau ?
Pareil .. mais j'en attend rien... Faut compter en mois avec Volkswagen... C'est peut être un mail pour calmer la plèbe
J'ai mis une réponse plus détaillées sur le topic des bugs mais pour moi après 3 charge ca semble marcher plutôt correctement (j'utilise les heures préférés pour charger en heures creuses, pas du tout le départ programmée)
Le 17/12/2022 à 10:13, Ranu a dit :
Tu avais envoyé un mail en disant je veux OTA à volkswagen ID ?
Le 20/12/2022 à 07:55, ID.3 a dit :
Le déploiement de la version 3.0 en ce moment concerne tous les véhicules et plus seulement les 1000 premières personnes à avoir envoyer le mail.
Le 20/12/2022 à 16:46, Razormark a dit :
Justement c'est ce que je cherche à savoir avec certitude. Merci
Pourtant, en contactant VW sur facebook pour leur demander comment avoir la MAJ, la seule chose qu’ils demandent, c’est si on a envoyé le mail pour dire qu’on veut la MAJ …
