Cayenne13
Verrouillage automatique des portes
Déjà un résume des options de vérouillage des portes dans LeafSpy (en anglais):
Door Lock/Unlock
Use this option to change how all doors are unlocked and to change the automatic door lock/unlock settings of the Leaf.
Presses to unlock all doors This option determines how many presses of the door button are needed to unlock all doors. The factory default is one press to unlock the driver's door and two presses to unlock all doors. Use this option to have one press unlock all doors or to change back to having two presses unlock all doors.
Automatic This option is the master control for the automatic lock and unlock functions.
Lock & Unlock Both door locking and unlocking will be controlled automatically based on conditions set below.
Unlock Only door unlocking will be controlled automatically based on conditions set below.
Lock Only door locking will be controlled automatically based on conditions set below.
Off Automatic door locking and unlocking is disabled.
Auto Lock This option is enabled if either automatic Lock & Unlock or just Lock has been enabled. Select one of the two choices to control when all the doors are locked.
At 15 MPH All doors are locked when the Leaf reaches a speed of 15 MPH (24km/h).
Out of Park All doors are locked when the Leaf shifter is taken out of Park.
Auto Unlock This option is enabled if either automatic Lock & Unlock or just Unlock has been enabled. Select one of the four choices to control when all the doors are unlocked.
All Doors - Ign On->Off Unlock all doors when the Leaf is Turned Off.
All Doors - Shift into Park Unlock all doors when the Leaf is Shifted into Park.
Driver Door - Ign On->Off Unlock only the driver's door when the Leaf is Turned Off.
Driver Door - Shift into Park Unlock only the driver's door when the Leaf is Shifted into Park.
Pour info: Ce ne sont pas toutes les PSA qui verrouillent automatiquement en roulant, puisque ma Ion de 2017 ne verrouille pas non plus.
Si elle a le bouton de verrouillage intérieur, tu peux toujours essayer la méthode des autres modèles PSA pour l'activer.
Tu mets le contact sans démarrer et tu appuis sur le bouton de verrouillage en restant appuyer pendant 10 secondes.
Normalement, si c'est une vrai PSA, cela l'active (mais je crois que c'est du mitsu ^^)
Merci pour ta confirmation de faisabilité avec Leaf SpyPro !!
Quelqu'un dans le 13 possédant SpyPro pouvant me faire cette manip ?
Car je ne sais pas si en achetant sous Android cette appli elle fonctionnera automatiquement avec mon ODB2 ( qui fonctionne déjà avec la version Lite ) et je me vois mal encore en trouver un autre compatible ...
Qu'en pensez-vous ? c'est pas pour les 16.50€ mais je râlerai si après ça ne fonctionnerait pas ..
Je me déplace ...
Merci d'avance
J'ai testé la nouvelle methode de la page 3-7 du manuel papier pour la Leaf 2.0 :
"Verrouillage automatiques des portieres ( selon modele,) "
Mais ça ne marche pas !!..en France !!
Donc operation Leaf Spy Pro ..
Bonsoir,
non les concessionnaires ne peuvent pas le faire pour la simple raison que la loi européenne a été modifiée il y a quelques années et interdit le verrouillage automatique. Donc les Nissan vendues en Europe (ou en France?) n'ont plus cette option. Par contre comme c'est autorisé dans d'autres pays, la possibilité technique existe toujours mais n'est plus accessible directement. Par contre leaf spy en version pro permet de le faire. C'est ce que j'ai utilisé pour ma leaf version 2014... Comme c'est une opération à faire une seule fois, il y a aussi moyen de demander à quelqu’un qui a leaf spy pro pas trop loin de chez vous de faire la programmation pour vous.
Etrange, tous les autres constructeurs seraient "hors la loi" ??? Il me semble aussi que les qashqai ont ce verrouillage automatique.
Quel est l'article de loi en question ? surtout que l'on peut toujours verrouiller les portes manuellement...
C'est une super nouvelle ça alors..!
Y aurait il une âme charitable équipée sur IDF (93/93/77) qui serait dispo pour me l'activer?
Je possède un dongle ODB 2 mais je ne sais pas le faire fonctionner..
Merci par avance
Ce n'est pas tant le verrouillage automatique qui est interdit mais le fait de verrouiller en roulant et que le véhicule n'est pas en capacité de déverrouiller automatiquement en cas d'accident. Tous les véhicules nouvellement commercialisés qui disposent de ce dispositif peuvent verrouiller les portes en roulant sauf que pour la nouvelle Leaf, ce système n'est pas implanté donc bien que la fonction de verrouillage automatique est existante et utilisable, pour être en conformité avec la réglementation européenne, Nissan a préféré désactivé cette fonction de la même façon que Nissan n'a pas anticipé pour mettre l'appel automatique d'urgence au 112 en cas d'accident alors que pour tous les véhicules commercialisés depuis le 1er avril cette fonctionnalité est obligatoire parce que l'homologation a été effectuée avant cette date...
Ce n'est pas tant le verrouillage automatique qui est interdit mais le fait de verrouiller en roulant et que le véhicule n'est pas en capacité de déverrouiller automatiquement en cas d'accident...
Donc, toutes les voitures et tous les conducteurs sont hors la loi?
Je ne connais AUCUNE voiture où on ne puisse pas verrouiller en roulant.
Tu as le texte, stp?
le verrouillage des portières n'existe pas depuis si longtemps que cela
avant les années 1980, il me semble qu'aucune voiture n'étais équipée
donc toutes les voitures de collection !
une époque que les moins de 20 ans ne peuvent pas connaitre?????
comme le dis si bien la chanson
Patrick
Je pense (sans certitude, je ne connais pas les textes de référence) que l'idée est la suivante :
- Si le véhicule verrouille automatiquement les portes lorsqu'il roule, il doit aussi déverrouiller automatiquement lors d'un accident.
- Si l'utilisateur verrouille en roulant, il n'y a pas de question à se poser.
Bonjour, j'ai leaf spy pro pour android version 0.45.119, mais je n'ai pas l'écran pour vérouiller/dévérouiller les portes.
J'ai le Vgate ICar2 Bluetooth OBDII pourtant recommandé par James de Lemon-Tea.
Je n'ai que 4 écrans de disponible.
1381473189_Screenshot_20181022-145513_LeafSpyPro.thumb.png.c1d35d88b4dd0c41caf719bd7b66ed79.png
Si quelqu'un a une solution je suis preneur :-)
