[App Tierce] Teslamate : datalogger local et gratuit
Je suis à la recherche d'une mise à jour des dashboards car la carte ne fonctionne plus. Qui pourrait les partager de nouveau ?
Le 18/06/2024 à 19:18, wdiz a dit :
Bon, je ne sais pas si c'est la mise à jour ou pas mais maintenant j'ai ça dans les Logs :
2024-06-18 17:17:35.024 [warning] TeslaApi.Error / %{"error" => "{\"error\": \"timeout\"}", "error_description" => "", "response" => nil}
T'a ca après l'update en 1.29.2 ?
Je viens d'aller voir mes logs : ras (suis en 1.29.2)
Le 18/06/2024 à 21:24, slyTM3 a dit :
Oui après l'update, mais c'est bon, cette nuit le token s'est bien rafraichi.
  • 3 semaines plus tard...
Version 1.30 disponible : https://github.com/teslamate-org/teslamate/compare/v1.29.2...v1.30.0
Citation
As always with many improvements. Cleaner LFP battery handling, 100x speed improvement in dashboards and much, much more. Enjoy it.
New features
Improvements and bug fixes
Build, CI, internal
  • build(deps): bump crate-ci/typos from 1.21.0 to 1.22.9 (#4021)
  • build(deps): bump express from 4.18.2 to 4.19.2 in /website (#3790)
  • chore: update @docusaurus/core and @docusaurus/preset-classic dependencies to v3.4.0 and react and react-dom to 18.3.1 (#4046 - @JakobLichterfeld)
  • build: specify node.js version for Netlify in base dir as latest lts major version (#4046 - @JakobLichterfeld)
  • style: fix single quoted string in car_live (#4049 - @JakobLichterfeld)
Dashboards
  • Improve drive details (#4004 - @jheredianet)
  • Improve visualizations on Battery Health dashboard (#4005 - @jheredianet)
  • Update drives.json: show drives with duration=0 but distance>0 (#3867 - @DrMichael)
  • Improve performance of timeline dashboard (#4019 - @swiffer)
  • Fix detection of missing data (geofence condition) in timeline dashboard (#4019 - @swiffer)
  • Fix time filter for links to trip dashboard in timeline dashboard (#4019 - @swiffer)
  • Reduce number of queries executed in overview dashboard to increase performance (#4019 - @swiffer)
  • Ensure Index usage when getting temperatures in overview dashboard (#4019 - @swiffer)
  • re-enable time picker by default in drive-details, charge-details dashboards (#3985)
  • Improve "Charges" dashboard (#4031 - @jheredianet)
  • Improve "Drives" dashboard (#4033 - @jheredianet)
  • Update overview.json: Add Distance (#4034 - @DrMichael)
  • Update overview.json: fix Net (#4045 - @DrMichael)
  • update overview dashboard to fix units for energy consumption (#4048 - @JakobLichterfeld)
  • use lfp_battery setting in dashboards & speed up updates dashboard (#4051 - @swiffer)
Translations
Documentation
Le 10/07/2024 à 05:30, thom75 a dit :
Même une version  1.30.1 qui est pluôt un Hotfix
This is a hotfix release to work around the map fit problem in the new Upstream Grafana. As soon as a new Grafana version is available, we will update again.
  • downgrade grafana until maps issue in upstream grafana is resolved (#4071 - @swiffer)
Build, CI, internal
Dashboards
  • Configure Grafana to use browser language / date formats (#4064 - @swiffer)
  • Fix hard coded information (timezone and orgId) (#4056 - @jlestel)
Translations
  • 2 mois plus tard...
Le 18/06/2024 à 20:00, l@blanch€ a dit :
Salut tout le monde. Idem j'ai pas mal de dashboards qui ne fonctionnent plus. Quelqu'un aurait des sources pour en télécharger des fonctionnels et sympas svp ?
Encore une petite question, j'en profite 😅
Vous avez les coûts des supercharges qui remontent automatiquement ?
Pour ma part c'est à 0...dans le géorepérage de Teslamate j'ai rentré mon coût de recharge au travail donc pour ça c'est bien calculé mais que dalle pour les supercharges alors que j'ai lu que ça devait remonter...
  • 2 semaines plus tard...
J'ai installé il y a quelques années teslamate sur un raspberry PI en suivant des tutos.
Il fonctionne encore très bien, j'envisage de faire migrer Teslamate sur mon NAS Synology.
En attendant de le faire, j'aimerais simplement savoir si quelqu'un pourrait m'indiquer où modifier l'adresse du MQTT broker qui doit être paramétré en localhost sur le raspberry pour le rediriger vers le MQTT du NAS.
Bonsoir,
Finalement en suivant un bon tuto : https://mariushosting.com/how-to-install-teslamate-on-your-synology-nas/
j'ai installé via portainer Teslamate.
je me suis arrêté à l'authentification avec un jeton. Avant d'aller plus loin :
Est-ce que je peux activer mon nouveau teslamate en parallèle de celui qui est sur la Resberry PI ? Est-ce que ça pose un problème ?
Comment récupérer les données qui datent de 5 ans sur mon Raspberry PI vers le NAS en utilisant Portainer (ou pas) ?
Sur le raspberry pi, j'ai également portainer qui est installé.
Est ce que quelqu'un pourrait me guider pour faire cette manip car je je suis très peu familier avec Docker et Portainer
J'ai fait la sauvegarde en ligne de commande sur le raspberry... OK
Pour la restauration sur le NAS, les lignes de commandes semblent différentes...
Quelqu'un saurait me guider avec Portainer ?
Le 25/09/2024 à 18:35, marc54425 a dit :
Il faut te connecter en SSH et root sur ton NAS puis rentrer les commandes suivantes :
cd [chemin où se situe ton fichier de backup]
docker stop [nom de ton container teslamate]
docker exec -i [nom de ton container base de données teslamate] psql -U teslamate teslamate << .
  drop schema public cascade;
create schema public;
create extension cube;
create extension earthdistance;
CREATE OR REPLACE FUNCTION public.ll_to_earth(float8, float8)
    RETURNS public.earth
    LANGUAGE SQL
    IMMUTABLE STRICT
    PARALLEL SAFE
    AS 'SELECT public.cube(public.cube(public.cube(public.earth()*cos(radians(\$1))*cos(radians(\$2))),public.earth()*cos(radians(\$1))*sin(radians(\$2))),public.earth()*sin(radians(\$1)))::public.earth';
docker exec -i [nom de ton container base de données teslamate] psql -U teslamate -d teslamate < [nom de ton fichier.bck]
docker start [nom de ton container teslamate]
Et normalement, magie, tes données auront été intégrées à ton nouveau teslamate.
ok merci,
Je vais tenter de le faire tranquillement ce weekend pour pas faire de bêtises.
Hello
Je voulais essayer de modifier mon install pour ajouter l'encryption key. Mais je rencontre 2-3 soucis :
- Où trouver la clé? J'ai lu que c'est dans les logs mais je ne les trouve pas sur ma VM Oracle
- Plus gênant, j'ai essayé de rajouter la ligne dans le fichier compose sauf que ça me fait une erreur de droit quand j'essaye d'enregistrer le fichier modifié, que ce soit en le récupérant via filezilla ou en me connectant en SSH. Je rate quoi?
Merci pour vos pistes!
FInalement, j'y suis arrivé :
- N'importe quelle clé fonctionne : j'ai tapé une suite aléatoire de chiffres et lettres
- il suffisait de faire un sudo nano au lieu de nano seulement...
Modifié par David42fr
j'en suis à la grosse commande
c'est quoi  ?
j'ai dans les conteneurs :
TeslaMate-DB
TeslaMate
TeslaMate-GRAPHANA
TeslaMate-MOSQUITTO
Modifié par marc54425
Le 28/09/2024 à 09:54, marc54425 a dit :
c'est quoi  ?
TeslaMate-DB
TeslaMate
TeslaMate-GRAPHANA
TeslaMate-MOSQUITTO
C'est teslamate tout court. C'est ce container qui s'occupe d'interroger les serveurs Tesla. L'arrêter permet d'éviter les perturbations qui pourraient survenir lors de la restauration des données.
Le fichier de backup est fourni dans l'avant-dernière commande, je l'ai mis entre crochets ne connaissant pas son nom chez toi.
le lance la commande :
docker exec -i TeslaMate -U teslamate teslamate << .
    LANGUAGE SQL
    IMMUTABLE STRICT
    PARALLEL SAFE
et erreur :
Error response from daemon: Container a5a0a07e24ac8d72a4d04169099c8b85504e05e69798a8ad66605169556db783 is not running
Le 28/09/2024 à 10:39, marc54425 a dit :
    LANGUAGE SQL
    IMMUTABLE STRICT
    PARALLEL SAFE
et erreur :
Pardon, j'ai lu trop vite ta question précédente, je pensais que c'était la première commande ! Le container base de données, c'est celui suffixe par DB (DataBase, base de données en français).
Il te faut le lancer (soit en ligne de commandes soit par container manager) et la grosse commande fonctionnera.
Désolé !
Citation
Pardon,
pas de pb on va y arriver :)
docker exec -i TeslaMate-DB -U teslamate teslamate << .
etc...
TeslaMate-DB  est en cours d'excution
mais j'ai cette erreur :
OCI runtime exec failed: exec failed: unable to start container process: exec: "-U": executable file not found in $PATH: unknown
Le 28/09/2024 à 10:57, marc54425 a dit :
etc...
docker exec -i TeslaMate-DB psql -U teslamate teslamate
Manque psql ?
Impeccable !
L'importation s'est bien passée.
Ca a pris un temps incroyablement long, plus d'une heure, il faut dire le backup faisait plus d'1Go
Maintenant je vais essayer de lancer le nouveau teslamate.
Me connaissant, je pense que je reviendrai vous demander de l'aide :)
En attendant un grand merci
J'ai ajouté le token, c'est OK
L'affichage des pages est incroyablement lent... j'espère que ça va se normaliser, pourtant au niveau du NAS il reste en dessous des 5% d'utilisation du CPU 😗
C'est bon, ça s'est calmé, ça semble fonctionner :)
J'aimerais pouvoir accéder au MQTT de mosquito TeslaMate. A priori y a pas de port exposé en dehors du conteneur.
Comment est ce que je peux rendre ce port accessible en dehors du conteneur ?
j'ai modifié les ports dans TeslaMate-MOSQUITTO
1883 1883
Le port apparait dans MQTT explorer, pas de donnée de Teslamate
J'ai forcement loupé un truc
