[App Tierce] Teslamate : datalogger local et gratuit
Le 15/07/2023 à 08:57, Jeep63 a dit :
Je viens d'essayer un reboot sur la VM, et maintenant le docker-compose ne marche même plus , j'ai çà :
 sudo docker-compose up -d
Traceback (most recent call last):
  File "urllib3/connectionpool.py", line 677, in urlopen
  File "urllib3/connectionpool.py", line 392, in _make_request
  File "http/client.py", line 1277, in request
  File "http/client.py", line 1323, in _send_request
  File "http/client.py", line 1272, in endheaders
  File "http/client.py", line 1032, in _send_output
  File "http/client.py", line 972, in send
  File "docker/transport/unixconn.py", line 43, in connect
FileNotFoundError: [Errno 2] No such file or directory
During handling of the above exception, another exception occurred:
  File "requests/adapters.py", line 449, in send
  File "urllib3/connectionpool.py", line 727, in urlopen
  File "urllib3/util/retry.py", line 410, in increment
  File "urllib3/packages/six.py", line 734, in reraise
urllib3.exceptions.ProtocolError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
  File "docker/api/client.py", line 214, in _retrieve_server_version
  File "docker/api/daemon.py", line 181, in version
  File "docker/utils/decorators.py", line 46, in inner
  File "docker/api/client.py", line 237, in _get
  File "requests/sessions.py", line 543, in get
  File "requests/sessions.py", line 530, in request
  File "requests/sessions.py", line 643, in send
  File "requests/adapters.py", line 498, in send
requests.exceptions.ConnectionError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
  File "docker-compose", line 3, in <module>
  File "compose/cli/main.py", line 81, in main
  File "compose/cli/main.py", line 200, in perform_command
  File "compose/cli/command.py", line 70, in project_from_options
  File "compose/cli/command.py", line 153, in get_project
  File "compose/cli/docker_client.py", line 43, in get_client
  File "compose/cli/docker_client.py", line 170, in docker_client
  File "docker/api/client.py", line 197, in __init__
  File "docker/api/client.py", line 222, in _retrieve_server_version
docker.errors.DockerException: Error while fetching server API version: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
[4919] Failed to execute script docker-compose
[opc@instance-20220328-2250 ~]$
Quelqu'un a une idée pour m'aider ?
Merci à tous
Bon, çà y est j'ai retrouvé mon serveur !
Pour ceux qui rencontrent le même problème, voilà ce que j'ai fait :
- Reboot de la VM (sudo reboot )
- relancer docker (sudo systemctl start docker)
- refaire un docker-compose  (sudo docker-compose up -d)
et c'est reparti !
Hello, alors j'ai refait comme ci je n'avais jamais installé Teslamate. A 2 3 reprises on te dira que le fichier existe, dans ce cas je suis allé voir dedans si les commandes étaient bien correctes. J'ai parfois effacé et remis les commandes pour être sûr.
Je n'ai perdu aucune infos et c'est reparti comme avant. Tu peux tenter ainsi.. Tiens moi au jus :)
Bon à mon tour de constater que mon TeslaMate ne fonctionne plus.
Les derniers trajets enregistrés datent de septembre 2022 et rien depuis : les écrans affichent "No Data".
Ce qui est bizarre, c'est que j'ai le tracé des déplacements mais pas les data (vitesses, odomètre, etc...)
J'ai les données des recharges, même récentes, mais pas des trajets.
J'ai remis à jour TeslaMate et relancé la machine mais toujours pas de données.
Quelqu'un a une idée de ce que je devrais regarder?
note : j'ai aussi rallongé le timeout à 2 min.
Voici un exemple de dashboard maintenant:
Le tracé de la carte est correct, il manque juste plein de données. Ce qui m'étonne, c'est d'avoir une moitié des données et pas l'autre.
Si c'était un problème de connexion, cela devrait être tout ou rien, non?
Modifié par jpsurlaroute
Le 19/07/2023 à 11:18, lesommer35 a dit :
Peut-être un problème de mauvaise fermeture des trajets 🤔
Après la mise-à-jour / redémarrage, la base de donnée est en train de se reconstruire, j'ai l'impression.
J'ai des pages maintenant qui sont complètes avec mes trajets récents avec toutes les données mais d'autres où c'est incomplet, pourtant décrivant le même trajet.
Peut être un changement de syntaxe des json dans ce cas, peut-être. Mais je ne sais pas trop où regarder et comment déchiffrer la base de donnée. Pas encore mis ma tête 100% dedans...
Mais pour les trajets entre Septembre 2022 et maintenant, je n'ai que des données partielles. Données de charge : OK. Position GPS : OK mais pas de données de vitesse, température, odomètre etc...
Il est possible que cela soit dû au fait que le token Tesla a expiré en Septembre et je ne l'ai pas renouvelé... C'est clair que je regarde les données TeslaMate surtout lors de mes migrations estivales.
NB le pb de lenteur de fermeture des trajets qui obligeait à augmenter les timeout est traité dans la V1.27
Pour les anciens trajets comme dans le cas de @jpsurlaroute cf ici
Modifié par MrFurieux
Bonjour. J'utilise Teslamate (très novice) et j'ai mis dans Géorepérages les lieux où je me charge le plus souvent. Par contre chez moi, je vais changer d'offre d'electricité. Je ne sais pas encore si je passe en Tempo ou en Heure pleine, heure creuse. Dans tous les cas, est-il possible de le "dire" à Teslamate? Je n'ai que le choix entre prix au kwh ou min et un prix fixe.
Merci.
Non pas le choix. Moi j'ai mis 10c, je recharge la plupart du temps en bleu hc.
  • 2 semaines plus tard...
Bonjour à tous, j'ai un camarade qui cherche une solution simple, pour réaliser un tableau journalier des kilomètres parcourus pour justifier plus facilement les indemnités kilométriques dans une société. Est-il possible d'extraire depuis TESLAMATE. J'ai voulu faire un copier coller dans un fichier excel mais j'ai une seule colonne avec toutes les informations pas très pratique.image.thumb.png.f7e3081d18151a227bdfac228359a09b.png
Le 01/08/2023 à 19:27, l@blanch€ a dit :
Tu peux tenter ta chance avec une requête du genre :
select sum(km_fin-km_debut), date from drives group by date order by date desc
C'est un premier jet, comme ça...
Le 01/08/2023 à 21:26, l@blanch€ a dit :
oups je suis perdu ou faudra t-il lancer la requête
La requête qui va bien :
SELECT
sum(distance) as "Distance parcourue",
  to_char(start_date, 'DD/MM/YYYY') as "Date"
FROM drives
WHERE  $__timeFilter(start_date)
  group by to_char(start_date, 'DD/MM/YYYY')
ORDER BY to_char(start_date, 'DD/MM/YYYY')
Si tu ne veux pas filtrer sur la date (en sélectionnant la période dans le menu en haut à droite), tu retires toute la ligne débutant par where.
Ca se passe dans la partie "explore" du menu de gauche :
Bien penser à mettre le format de sortie "table" pour éviter d'avoir un graphique difficilement exploitable.
J'ai compris, le problème c'est de récupérer les informations dans un tableau style excel. Car le copier coller ne fonctionne pas
Le 01/08/2023 à 21:51, l@blanch€ a dit :
Merci de m'avoir donner un coup de main j'ai trouvé ou ont peut exporter image.thumb.png.739f42a36281dc440bf67331c4c2dc7f.png
Pour que tout le monde ait la solution : mettre la requête dans un dashboard puis cliquer sur l'en-tête
et enfin
Avant et enfin si vous voulez un fichier exploitable il faut faire data option et sélectionner Download for excel image.thumb.png.7ec50a2c62419117f362c9d341e8df5c.png
Le 19/07/2023 à 14:29, MrFurieux a dit :
Ah cool, ils ont finalement ajouté un index ?
Le 09/08/2023 à 19:06, MrFurieux a dit :
Oui
Ok je ferai la mise à jour et testerai.
Même clôturer un trajet manuellement prend plus d'une minute...
J'ai un soucis avec Teslamate. Cela fait plusieurs fois que sans raison il est injoignable avec le message "échec du bilan de santé"
J'ai dû relancer à chaque fois depuis le PC le docker et ça repart.
Soucis, la je n'ai pas le pc à portée de main, et je ne peux donc pas réaliser cette opération. J'ai relancé sur Oracle la VM, mais forcément maintenant je n'ai même plus accès au site Web..
C'est bien galère cette histoire, avez-vous eu déjà ce soucis ? Je précise que je suis sur la dernier version et sur ma private key est sur mon mac à la maison.
J'aurais aimé pouvoir lancé des commandes à distance de puis le pc.
Existe t il une solution pour le relancer à distance dans mon cas ?
Merci !
  • 3 semaines plus tard...
J'en suis à mon 5ieme essai (à plusieurs jours d'interval) pour m'inscrire sur oracle, mais rien à faire ca bloque toujours.😡
je suis seul dans ce cas ??
Petit rex, suite à la vente de ma SR+ et mon auto parrainage sur un autre compte Tesla pour l’achat d’une LR . Super simple pour voir mon nouveau véhicule
- j’ai ajouté mon ancien compte tesla comme conducteur dans l’app Tesla histoire de récup mon profil Cloud
- juste redémarre le conteneur de Teslamate : la voiture apparaît
Le 10/08/2023 à 15:04, Sobyte a dit :
Merci !
J'ai exactement le meme soucis, ca a bien marché 2 semaines et maintenant je dois relancer le docker tous les 2J ou remettre les token tres souvent.
Le 07/09/2023 à 10:35, suistrop a dit :
Ça continue à me le faire, temps en temps ça se met en indisponible. Sans raison apparente..
Je dois relancer un coup de restart et ça bien sûr sur le Mac que je n'ai pas forcément à portée de main.
Ça m'est arrivé pendant mes vacances, j'ai perdus quelques précieux milliers de km..
Hello tout le monde, je n'arrive pas à faire de backup de mon Teslamate qui est sous Oracle cloud.
J'ai l'erreur no such file or directory. Je ne comprends pas trop la commande, je veux l'enregistrer en dur sur mon Mac depuis lequel j'exécute le terminal.
Quelque peut-il me venir en aide ?
Merci !
