bobjouy
[App Tierce] Teslamate : datalogger local et gratuit
Bonjour, j'ai un problème avec la mise à jour en mode debian
  Citation
npm install --prefix ./assets && npm run deploy --prefix ./assets
added 17 packages, removed 177 packages, and audited 508 packages in 6s
50 packages are looking for funding
  run `npm fund` for details
8 high severity vulnerabilities
To address issues that do not require attention, run:
  npm audit fix
Some issues need review, and may require choosing
a different dependency.
Run `npm audit` for details.
npm notice
npm notice New minor version of npm available! 7.6.3 -> 7.17.0
npm notice Changelog: https://github.com/npm/cli/releases/tag/v7.17.0
npm notice Run npm install -g npm@7.17.0 to update!
npm notice
> deploy
> webpack --mode production --stats-colors
[webpack-cli] TypeError: Cannot read property 'name' of undefined
    at new WebpackCLI (/usr/src/teslamate/assets/node_modules/webpack-cli/lib/webpack-cli.js:18:22)
    at runCLI (/usr/src/teslamate/assets/node_modules/webpack-cli/lib/bootstrap.js:7:21)
    at Object.<anonymous> (/usr/src/teslamate/assets/node_modules/webpack-cli/bin/cli.js:23:5)
    at Module._compile (internal/modules/cjs/loader.js:778:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    at Module.load (internal/modules/cjs/loader.js:653:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    at Module.require (internal/modules/cjs/loader.js:692:17)
    at require (internal/modules/cjs/helpers.js:25:18)
npm ERR! code 2
npm ERR! path /usr/src/teslamate/assets
npm ERR! command failed
npm ERR! command sh -c webpack --mode production --stats-colors
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2021-06-17T11_05_20_693Z-debug.log
[jeu. juin 17 11:05:51]/usr/src/teslamate>npm install -g npm@7.17.0
npm ERR! code MODULE_NOT_FOUND
npm ERR! Cannot find module 'agentkeepalive'
Dérouler
Une idée de comment corriger ça ?
  Le 17/06/2021 à 11:10, Arai680 a dit :
Dérouler
L'utilisation des versions containers permet d'éviter ce genre de souci.
Ceci étant l'erreur est plutôt claire, il manque le module node.js "agentkeepalive", une petite recherche sur ton moteur de recherche favoris devrait t'aider à résoudre le problème :)
Merci de ton aide mais si je décide de mettre dans un debian c'est qu'il y a une raison (comme par exemple l'inutilité d'avoir un docker sur un proxmox).
De plus, si tu regardes bien, il y a deux commandes, le npm de maj de la doc et la mise à jour de npm conseillé dans le log.
Pour corriger cela un collègue m'a conseiller de mettre @latest plutôt que le tag de version et ça passe, pas besoin de agentkeepalive.
Maintenant il ne reste que les 8 errors de security + le warning de taille trop importante (mais ça c'est le développeur qui doit le gérer)
Il est tout à fait possible d'installer docker sur une debian, virtualisé ou non, mais passons.
NPM n'est que le gestionnaire de packages pour Node.js.
Du coup à priori tu n'as pas besoin d'aide ici, et si c'est le cas tu peux toujours ouvrir une issue sur le github d'Adrian, ou celui de Node.js ;)
Ce Teslamate fait rêver.
J’ai regardé les conditions d’installations et il y a un mot sur deux que je ne comprends pas. 😅
il faut dire que si j’ai choisi d’avoir un Mac, c’est justement parce qu’il sait tout faire sans que j’ai besoin de programmer quoi que ce soit!
je crois que je vais devoir attendre l’arrivée d’une hypothétique appli…
  Le 18/06/2021 à 06:23, Casimir50 a dit :
Dérouler
Il n'y aura jamais juste une "appli" il faut un serveur pour collecter en continu les données depuis les serveur Tesla (sauf si Tesla intègre ces fonctions dans sa propre appli bien sûr). Soit tu t'auto-héberges avec Teslamate + un peu d'huile de coude, sois tu utilises un service payant comme Teslafi qui gère tout pour toi.
  Le 18/06/2021 à 07:29, Casimir50 a dit :
Merci pour ta réponse. C'est donc mort pour moi. C'e n'est pas au je manque d'huile de couderais vraiment de compétences.
Dérouler
Installer Teslamate sur un Raspberry c’est vraiment simple.
La procédure que j’ai utilisée :
https://www.teslamodel3.fr/2020/05/11/installer-teslamate-sur-raspberry-pi/
J'ai installé Teslamate sur une VM de mon NAS Unraid depuis qqs temps. Tout fonctionnait bien sauf que depuis hier Teslamate n'est accessible que qqs minutes. Je reboot la VM, ca fonctionne qqs minutes puis KO... J'ai essayé de faire un update depuis le terminal de la VM (cd /Docker, puis docker-compose pull) mais j'ai un problème d'espace disque... que faire ? Merci de votre aide.
PS: Suis une buse en linux...
Message erreur:
DF me donne ça:
  Le 22/06/2021 à 19:11, frankie666 a dit :
Message erreur:
DF me donne ça:
Dérouler
Tu n'as plus de place sur ta partition /, il faut que tu fasses du ménage quelque part, en supprimant des vieux backups si tu en fais par exemple.
Merci de ton retour. Je m'en doutais mais j'ai rien sur cette VM à part un reste de Jeedom et Teslamate.
J'ai 3 questions :
1. C'est quoi la partition / ?
2. C'est overlay qui semble full pas tmpfs qui contient Jeedom, donc il faut faire de la place sur overlay, juste ?
3. N'est-il  pas possible d'augmenter la taille de cette partition ?
Désolé des question de noobs...
Merci.
  Le 22/06/2021 à 19:23, frankie666 a dit :
J'ai 3 questions :
Merci.
Dérouler
1. En gros c'est l'équivalent de ton C sous Windows, partition système et tout est stocké dedans, en tout cas dans ton cas car rien n'est séparé.
2. L'overlayfs est lié à docker, ne t'y fie pas pour l'instant il faut clean en priorité le /
3. Si mais tout dépend sur quoi est installé ta VM, si tu peux lui allouer d'avantage de disque de l'hôte, etc.. :)
C'est possible que ce soit des logs qui prennent de la place ça arrive souvent lorsque les logs ne sont pas sur une partition/lv séparé, jète un oeil en tapant "du -sh /var/log".
Tu peux aussi utiliser "du" comme méthode simple pour chercher où se trouvent les gros dossiers jusqu'à trouver les fautifs et y faire le ménage :)
  Le 22/06/2021 à 19:32, Yann73 a dit :
Dérouler
Alors /Var/log est vide et je comprends rien à du... et surtout je ne sais pas ce que je peux effacer.
Je pense faire un backup de Teslamate, refaire une VM plus gross et faire un restore.
Est-ce que le backup/restore est fiable ?
merci encore.
@frankie666,
  1. Est-ce que tu avais monté la console de management dans docker ? généralement sur le port 9000.(IPVM:9000) tu pourrais supprimé ainsi une image obsolète .....pour "gagner" de la place.
  2. Sauvegarde journalière ou pas ?, je ne pense pas que tu puisse refaire une sauvegarde vu le manque de place dans ta vm !
  3. Pour le restore d'une base de données (si correct) c'est OK pas de problèmes.
  4. Que donne le résultat de la commande docker ps ?
Modifié par dranreb38
