Cayenne13
Fonction "Follow-me,"
En page 2-67 du manuel nos Leaf 2.0 peuvent activer cette fonction qui permet de profiter de l'eclairage des phares pendant 30s apres avoir verrouiller la voiture ..
Seul pb c'est qu'au lieu d'etre automatique il faut tirer sur le levier des phares en position Auto pour activer la tempo 30s ..
En fait tu appuies sur off pour couper ta voiture .
Tu t'assures avant que ton commodo de commande des phares est bien sur auto .
Puis tu le tires vers toi 1 fois comme si tu voulais faire un appel de phare et là les feux s'allument pendant 30s .
Tu peux ensuite verrouiler tes portes .
Gadjet pratique si chez toi il fait sombre ..
Mais j'aurai preferé qu'il soit automatique .
Il y a des fonctions sur LSP pour changer ça:
Headlight Settings
This function is used to change the automatic on and off function of the Headlights.
If your Leaf did not originally come with the automatic headlight feature you will be given the option to enable it. However, you must have first install all the necessary hardware to support the automatic headlight feature for this to have any affect.
There are four controls. The first enables the battery saver function that tries to save the battery by not allowing the headlights to be left on for more than 5 minutes after the Leaf has been turned off. The second controls the delay used to keep the headlights on after the Leaf has been turned off and all doors have been closed. The third controls the sensitivity of the dusk sensor that automatically turns on the Headlights under dim light conditions. The fourth controls under what conditions the headlights are automatically turned on. On this fourth control it appears that not all conditions have been implemented on the Leaf or might vary by model year.
Battery Saver (off after 5 minutes)
• Enable (default)
• Disable (not recommended as you risk draining your 12 volt battery)
Auto Off Delay (After all doors closed)
• 45 Seconds (default)
• Off (0 seconds)
• 30 Seconds
• 60 Seconds
• 90 Seconds
• 120 Seconds
• 150 Seconds
• 180 Seconds
Auto On Sensitivity
• Normal (default)
• More
• Most
• Least
Auto On
• At twilight or wiper INT, LO, HI (default)
• At twilight or wiper LO, HI
• At twilight
• wiper INT, LO, HI
• wiper LO, HI
• Disabled
J'ai essayé avec LSP mais rien d'automatique.
De même quand j'ouvre la voiture le soir aucun lumière extérieure...
Personne ne sait comment changer cela ?
Cordialement,
Il y a ces fonctions sur LSP:
Headlight Settings
• Enable (default)
• Off (0 seconds)
• 30 Seconds
• 60 Seconds
• 90 Seconds
• 120 Seconds
• 150 Seconds
• 180 Seconds
Auto On Sensitivity
• Normal (default)
• More
• Most
• Least
Auto On
At twilight
• wiper INT, LO, HI
• wiper LO, HI
• Disabled
Est-ce que ça ne marche pas?
je ne crois pas
tu peux choisir l'intensité de déclenchement des feux, le moment - crépuscule, essuie-glaces intermittent, haut ou bas - mais je ne vis pas de programmation à l'ouverture des portes
j'avais la fonction "follow-me" sur mon C4 picasso
en sortie de spectacle le soir, c'était devenu inutile, toutes les voitures équipées s'allumais en même temps,
il restais donc impossible de distinguer celle que je cherchais
Patrick
Il n'y a pas de fonction concernant l'ouverture des portes, effectivement. C'est les phares qui restent allumés un certain temps après fermeture des portes.
Tu as réussi a les activer via leaf spy?
Je n'ai jamais essayé chez moi vu que je n'ai pas besoin de phares allumés mais je l'avais fait sur la LEAF 2.0 de @Cayenne13.
Il faut lui demander si ça marche bien comme prévu.
Avec LSP :
Fermeture des portes impec
Fonction follow me :
je verrais cela ce soir (cela utilise le senser des phares, donc cela ne pourra fonctionner que la nuit ou dans un endroit pas éclairé.
