Jeep63
21 -
Jeep63's Achievements
Bon, çà y est j'ai retrouvé mon serveur ! Pour ceux qui rencontrent le même problème, voilà ce que j'ai fait : - Reboot de la VM (sudo reboot ) - relancer docker (sudo systemctl start docker) - refaire un docker-compose (sudo docker-compose up -d) et c'est reparti !
Jeep63 a commencé à suivre [App Tierce] Teslamate : datalogger local et gratuit
Je viens d'essayer un reboot sur la VM, et maintenant le docker-compose ne marche même plus , j'ai çà : sudo docker-compose up -d Traceback (most recent call last): File "urllib3/connectionpool.py", line 677, in urlopen File "urllib3/connectionpool.py", line 392, in _make_request File "http/client.py", line 1277, in request File "http/client.py", line 1323, in _send_request File "http/client.py", line 1272, in endheaders File "http/client.py", line 1032, in _send_output File "http/client.py", line 972, in send File "docker/transport/unixconn.py", line 43, in connect FileNotFoundError: [Errno 2] No such file or directory During handling of the above exception, another exception occurred: Traceback (most recent call last): File "requests/adapters.py", line 449, in send File "urllib3/connectionpool.py", line 727, in urlopen File "urllib3/util/retry.py", line 410, in increment File "urllib3/packages/six.py", line 734, in reraise File "urllib3/connectionpool.py", line 677, in urlopen File "urllib3/connectionpool.py", line 392, in _make_request File "http/client.py", line 1277, in request File "http/client.py", line 1323, in _send_request File "http/client.py", line 1272, in endheaders File "http/client.py", line 1032, in _send_output File "http/client.py", line 972, in send File "docker/transport/unixconn.py", line 43, in connect urllib3.exceptions.ProtocolError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory')) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "docker/api/client.py", line 214, in _retrieve_server_version File "docker/api/daemon.py", line 181, in version File "docker/utils/decorators.py", line 46, in inner File "docker/api/client.py", line 237, in _get File "requests/sessions.py", line 543, in get File "requests/sessions.py", line 530, in request File "requests/sessions.py", line 643, in send File "requests/adapters.py", line 498, in send requests.exceptions.ConnectionError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory')) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "docker-compose", line 3, in <module> File "compose/cli/main.py", line 81, in main File "compose/cli/main.py", line 200, in perform_command File "compose/cli/command.py", line 70, in project_from_options File "compose/cli/command.py", line 153, in get_project File "compose/cli/docker_client.py", line 43, in get_client File "compose/cli/docker_client.py", line 170, in docker_client File "docker/api/client.py", line 197, in __init__ File "docker/api/client.py", line 222, in _retrieve_server_version docker.errors.DockerException: Error while fetching server API version: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory')) [4919] Failed to execute script docker-compose [opc@instance-20220328-2250 ~]$ Quelqu'un a une idée pour m'aider ? Merci à tous
Bonjour, Quand tu dis "j'ai repris l'install" qu'est-ce que tu as fait exactement ? J'ai le même problème que toi. J'accède bien en ssh à mon Oracle, docker tourne normalement, j'ai refait un docker compose : tout est OK. Par contre, je suis toujours en "indisponible" sur grafana .... ???
Bonjour, Depuis le 8/7/23 mon Teslamate Oracle ne reçoit plus aucune donnée. et je viens de recevoir un mail d'Oracle rm'informant de la modification de leur " policy in the Identity and Access Management (IAM)". Je ne sais pas si les deux sont liès. Quand je vais sur la page d'accueil j'ai 'Etat indisponible". Est-ce que quelqu'un a eu ce problème ? Merci à tous UPDATE : Je viens de voir que je n'étais pas le seul ... Y a t il une autre méthode que la réinstall complète ? Et dans cas de réinstallation, quid des données existantes ? Merci à tous
Evidement le mot de passe n'était pas admin admin ... de plus pour se loger en ssh sur oracle sans avoir la clef ssh cela risque d'être un peu compliqué... Par contre personne n'a eu le problème de se voir refuser l'accès par grafana ?
Bonjour, Aujourd'hui Mon grafana sur oracle me refuse l'acces ... mauvais mot de passe !? je n'ai rien changé. j'ai essayé un sudo docker-compose exec grafana grafana-cli admin reset-admin-password admin sans succes. Quelqu'un a eu le problème ? PS : mon acces à teslamate marche bien mais je ne peux pas aller sur les dashboards grafana
Ok ! Et le bon endroit c'est o^ù ? c'est le premier ou le deuxième "teslamate" ? d'ailleurs l'autre signifie quoi ? Merci de ton aide
OK tu as raison, mon utilisateur par défaut est Pi (original non ?) et l'utilisateur du yml est JPB. donc si je comprends ta remarque, pour faire une sauvegarde il faut que je créé un utilisateur jpb sur le pi et que je lance la commande en sudo ?
Merci, çà marche nickel sur mon install sur Oracle. Par contre çà ne fonctionne pas sur l'install locale sur le Pi dont je veut récupérer les datas pour les injecter dans l'install oracle. J'ai l'impression que les noms des bases sont différents . voilà ce que me donne portainer sur les containers qui tournent : et le docker-compose qui a créé tout çà (j'ai enlevé les mots de passe évidement): version: "3" services: teslamate: image: teslamate/teslamate:latest restart: unless-stopped environment: - DATABASE_USER=JPB - DATABASE_PASS= - DATABASE_NAME=teslamate - DATABASE_HOST=database - MQTT_HOST=mosquitto ports: - 4000:4000 volumes: - ./import:/opt/app/import cap_drop: - all database: image: postgres:latest restart: unless-stopped environment: - POSTGRES_USER=JPB - POSTGRES_PASSWORD= - POSTGRES_DB=teslamate volumes: - teslamate-db:/var/lib/postgresql/data grafana: image: teslamate/grafana:latest restart: unless-stopped environment: - DATABASE_USER=JPB - DATABASE_PASS= - DATABASE_NAME=teslamate - DATABASE_HOST=database ports: - 3000:3000 volumes: - teslamate-grafana-data:/var/lib/grafana mosquitto: image: eclipse-mosquitto:1.6 restart: unless-stopped ports: - 1883:1883 volumes: - mosquitto-conf:/mosquitto/config - mosquitto-data:/mosquitto/data volumes: teslamate-db: teslamate-grafana-data: mosquitto-conf: mosquitto-data:
Merci Yann, le conseil est sage. Par contre rien ne te permets de dire que l'utilisateur (moi en l’occurrence) fait du copier/coller sans rien comprendre.
merci ! çà marche
bonjour, J'ai un teslamate qui tourne sur oracle (merci pour le tuto !), et je voulais faire une sauvegrade, mais je narrive plus à me connecter en ssh, j'ai l'erreur suivante : Quelqu'un peut m'aider ? merci
Bonjour, J'ai installé Teslamate sur oracle avec le tuto du début du forum. Avec quelques ajustements çà a marché. Par contre le n'arrive pas à péréniser les dashboards fournis dans le zip. Je les importe, nickel çà marche bien. Dès que je sors de Teslamate et que je reviens dessus, je retrouve les dashboard d'origine. Quelqu'un a-t-il eu ce problème et quelle est la solution ? Merci de votre aide
