chris33
Logs d'une IONIQ EV (H@cking)
Salut,
pour le moment le but de ce post n'est pas de dire comment j'ai accédé aux logs, mais de partager ces logs avec la communauté et voir si ça inspire quelqu'un... on y trouve des infos intéressantes à mon goût...
PARTAGEZ VOS IDEES ICI SVP pour commender:
<6>[    0.000000] Initializing cgroup subsys cpu
<5>[    0.000000] Linux version 3.1.10-tcc (dagyeong@cm03-c) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #2 SMP PREEMPT Wed Sep 27 16:34:59 KST 2017
<4>[    0.000000] CPU: ARMv7 Processor [412fc09c] revision 12 (ARMv7), cr=10c53c7d
<4>[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
<4>[    0.000000] Machine: tcc893x
<4>[    0.000000] Ignoring unrecognised tag 0x54434380
<6>[    0.000000] [total] reserved memory: base=0xb5f00000, size=0xa100000
<6>[    0.000000] [lk] reserved memory: base=0x82000000, size=0x1800000
<4>[    0.000000] Memory policy: ECC disabled, Data cache writealloc
<6>[    0.000000] L310 cache controller enabled
<6>[    0.000000] l2x0: 16 ways, CACHE_ID 0x410000c6, AUX_CTRL 0x70150001, Cache size: 524288 B
<6>[    0.000000]     pll_0:  cpu clock source
<6>[    0.000000]     pll_1:  600000 kHz (Fixed)
<6>[    0.000000]     pll_2:  1000000 kHz (Fixed)
<6>[    0.000000]     pll_3:  768000 kHz (Fixed)
<6>[    0.000000]     pll_4:  614400 kHz (Fixed)
<6>[    0.000000]     pll_5:  720000 kHz (Fixed)
<6>[    0.000000] div_pll_0:  cpu clock source
<6>[    0.000000] div_pll_1:  0 kHz (Fixed)
<6>[    0.000000] div_pll_2:  125000 kHz (Fixed)
<6>[    0.000000] div_pll_3:  0 kHz (Fixed)
<6>[    0.000000] div_pll_4:  0 kHz (Fixed)
<6>[    0.000000] div_pll_5:  0 kHz (Fixed)
<6>[    0.000000]       xin:  24000 kHz (Fixed)
<7>[    0.000000] On node 0 totalpages: 214784
<7>[    0.000000] free_area_init_node: node 0, pgdat c07dfdc0, node_mem_map c1298000
<7>[    0.000000]   Normal zone: 1024 pages used for memmap
<7>[    0.000000]   Normal zone: 0 pages reserved
<7>[    0.000000]   Normal zone: 123904 pages, LIFO batch:31
<7>[    0.000000]   HighMem zone: 1024 pages used for memmap
<7>[    0.000000]   HighMem zone: 88832 pages, LIFO batch:15
<6>[    0.000000] TCC clock driver initialized
<6>[    0.000000] PERCPU: Embedded 8 pages/cpu @c1a9f000 s9600 r8192 d14976 u32768
<7>[    0.000000] pcpu-alloc: s9600 r8192 d14976 u32768 alloc=8*4096
<7>[    0.000000] pcpu-alloc: [0] 0 [0] 1
<4>[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 212736
<5>[    0.000000] Kernel command line: vmalloc=256M console=null androidboot.serialno=000017092717032301A3 sys.quickboot.force.disable=1 androidboot.wrs.fb.reboot=0 androidboot.lk.hw.major=05 androidboot.lk.hw.minor=00 androidboot.wifimac= androidboot.btaddr=4CCC6ADDD226 androidboot.mode=emmc androidboot.dignostic= androidboot.memtype=2 wrs_ss_sbdev=/dev/block/mmcblk0p17 bootparts=0x7800000@0x0(hib),0x8800200@0x7800000(swp)
<6>[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[    0.000000] Memory: 32MB 807MB = 839MB total
<5>[    0.000000] Memory: 839200k/839200k available, 209376k reserved, 359424K highmem
<5>[    0.000000] Virtual kernel memory layout:
<5>[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
<5>[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
<5>[    0.000000]     DMA     : 0xff600000 - 0xffe00000   (   8 MB)
<5>[    0.000000]     vmalloc : 0xe0800000 - 0xf0000000   ( 248 MB)
<5>[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
<5>[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
<5>[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
<5>[    0.000000]       .text : 0xc0008000 - 0xc061d488   (6230 kB)
<5>[    0.000000]       .init : 0xc061e000 - 0xc0649580   ( 174 kB)
<5>[    0.000000]       .data : 0xc064a000 - 0xc07eb918   (1671 kB)
<5>[    0.000000]        .bss : 0xc07eb93c - 0xc0865e00   ( 490 kB)
<6>[    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
<6>[    0.000000] Preemptible hierarchical RCU implementation.
<6>[    0.000000] NR_IRQS:201
<7>[    0.000000] tcc_init_irq
<6>[    0.000000] sched_clock: 32 bits at 12MHz, resolution 83ns, wraps every 357913ms
<6>[    0.000000] Initialize the clocksource device.... rate[24000000] mult[-1498764629] shift[25]
<6>[    0.000000] Console: colour dummy device 80x30
<6>[    0.000000] console [ttyTCC-1] enabled
<6>[    0.060000] Calibrating delay loop... 1993.93 BogoMIPS (lpj=9969664)
<6>[    0.060000] pid_max: default: 32768 minimum: 301
<6>[    0.060000] Mount-cache hash table entries: 512
<6>[    0.060000] Initializing cgroup subsys debug
<6>[    0.060000] Initializing cgroup subsys cpuacct
<6>[    0.060000] Initializing cgroup subsys freezer
<6>[    0.060000] Initializing cgroup subsys blkio
<6>[    0.060000] CPU: Testing write buffer coherency: ok
<4>[    0.120000] Before waking up the secondary cpu(1), SEC_CPU_START_CFG value is 0
<4>[    0.120000] CPU1: Booted secondary processor
<2>[    0.180000] CPU1: Unknown IPI message 0x1
<6>[    0.180000] Brought up 2 CPUs
<6>[    0.180000] SMP: Total of 2 processors activated (3987.86 BogoMIPS).
<6>[    0.180000] print_constraints: dummy:
<6>[    0.180000] NET: Registered protocol family 16
<6>[    0.180000] tcc8930 GPIO initialized
<6>[    0.180000] ram_console: got buffer at b7e00000, size 100000
<6>[    0.180000] ram_console: uncorrectable error in header
<6>[    0.180000] ram_console: no valid data in buffer (sig = 0x00000000)
<3>[    0.180000] ram_console_init 0x0
<6>[    0.190000] console [ram-1] enabled
<4>[    0.190000] adc_init
<4>[    0.190000] tcc_adc_probe
<4>[    0.190000] attached TCC adc driver
<6>[    0.190000] TCC rotation driver initializing
<6>[    0.200000] TCC Scaler1 Device Driver Initializing.......
<6>[    0.200000] TCC Scaler-2 Driver Initializing.
<6>[    0.200000] TCC WMIXER Driver Initializing.
<6>[    0.200000] TCC WMIXER-1 Driver Initializing.
<6>[    0.200000] 2013/01/08 ver TCC WDMA Driver Initializing.
<6>[    0.220000] bio: create slab  at 0
<4>[    0.220000] LGD LA070WV7-SL01 LVDS driver lge7wvlcd_init
<5>[    0.220000] SCSI subsystem initialized
<6>[    0.220000] usbcore: registered new interface driver usbfs
<6>[    0.220000] usbcore: registered new interface driver hub
<6>[    0.220000] usbcore: registered new device driver usb
<6>[    0.230000] i2c-gpio i2c-gpio.4: using pins 94 (SDA) and 95 (SCL)
<6>[    0.230000] i2c-gpio i2c-gpio.5: using pins 146 (SDA) and 148 (SCL)
<6>[    0.230000] i2c-gpio i2c-gpio.6: using pins 45 (SDA) and 44 (SCL)
<6>[    0.230000] Advanced Linux Sound Architecture Driver Version 1.0.24.
<6>[    0.230000] Bluetooth: Core ver 2.16
<6>[    0.230000] NET: Registered protocol family 31
<6>[    0.230000] Bluetooth: HCI device and connection manager initialized
<6>[    0.230000] Bluetooth: HCI socket layer initialized
<6>[    0.230000] Bluetooth: L2CAP socket layer initialized
<6>[    0.230000] Bluetooth: SCO socket layer initialized
<6>[    0.230000] cfg80211: Calling CRDA to update world regulatory domain
<6>[    0.230000] Switching to clocksource timer0
<4>[    0.230000] stop_machine_cpu_stop smp=0
<4>[    0.230000] stop_machine_cpu_stop smp=1
<6>[    0.240000] Switched to NOHz mode on CPU #0
<6>[    0.240000] Switched to NOHz mode on CPU #1
<6>[    0.250000] NET: Registered protocol family 2
<6>[    0.250000] IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
<6>[    0.250000] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
<6>[    0.250000] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
<6>[    0.250000] TCP: Hash tables configured (established 65536 bind 65536)
<6>[    0.250000] TCP reno registered
<6>[    0.250000] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[    0.250000] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[    0.250000] NET: Registered protocol family 1
<6>[    0.250000] Unpacking initramfs...
<6>[    0.410000] Freeing initrd memory: 2652K
<6>[    0.410000] PMU: registered new PMU device of type 0
<4>[    0.410000] supported LCD panel type 21  system_rev:0x1000
<4>[    0.410000] LGD LA070WV7-SL01 LVDS driver lge7wvlcd_probe, name: lge7wvlcn_lcd
<7>[    0.410000] Registered led device: lcd-backlight
<4>[    0.410000] tcc8930_init_mmc(3)
<4>[    0.410000] tcc8930_init_tcc_dxb_ctrl (built Sep 27 2017 10:12:18)
<4>[    0.410000] [## BT ##] tcc_bluetooth_init
<4>[    0.410000] [## BT ##] tcc_bluetooth_probe
<4>[    0.410000] [## BT ##] tcc_bt_rfkill_set_power POWER_ON [0]
<4>[    0.420000] [## BT ##] rfkill_register Telechips Bluetooth
<4>[    0.420000] tcc8930_init_uart_map
<4>[    0.420000] proc_rotationinfo_init start /nproc_rotationinfo_init end /nhighmem bounce pool size: 64 pages
<6>[    0.440000] ashmem: initialized
<6>[    0.460000] fuse init (API version 7.17)
<6>[    0.460000] msgmni has been set to 942
<6>[    0.460000] io scheduler noop registered (default)
<6>[    0.460000] TCC Overlay driver initializing
<6>[    0.460000]  tccfb_init (built Sep 27 2017 10:13:28)
<6>[    0.460000]  tcc892X tca_fb_init (built Sep 27 2017 10:13:28)
<4>[    0.460000]  tca_fb_init LCDC:1  pRDMABase:f3000800  pWMIXBase:f3001900 pDISPBase:f3000100 end
<4>[    0.460000]  tccfb_init wmixer base:0xb7a00000 size:4194304
<6>[    0.460000] LCD panel is LG LGE LA070WV-SL01 800 x 480
<4>[    0.460000] tccfb_probe, screen_width=800, screen_height=480
<4>[    0.460000] map_video_memory (fbi=df98f668) used map memory,map dma:0xbea00000 size:01001000
<6>[    0.520000] fb0: tccfb frame buffer device
<4>[    0.520000]  TCC_OUTPUT_FB_setFBInfo info 0xdf98f668
<6>[    0.520000] tcc_viqe_init
<6>[    0.520000] tcc-uart.0: ttyTCC0 at MMIO 0xf7370000 (irq = 98) is a uart0
<6>[    0.520000] tcc-uart.1: ttyTCC1 at MMIO 0xf7380000 (irq = 99) is a uart1
<6>[    0.520000] tcc-uart.2: ttyTCC2 at MMIO 0xf7390000 (irq = 100) is a uart2
<6>[    0.520000] tcc-uart.3: ttyTCC3 at MMIO 0xf73a0000 (irq = 101) is a uart3
<6>[    0.540000] TCC Scaler0 Device Driver Initializing.......
<4>[    0.540000] [1;38m  tcc_lut_init
<6>[    0.540000] 2013/09/24 ver TCC LUT Driver Initializing.
<4>[    0.540000] [0m
<6>[    0.540000] TCCXX JPEG Encoder driver initializing
<4>[    0.540000] tcc_intr: init (ver 2.0)
<4>[    0.540000] wifi_pwr_init
<4>[    0.540000] wifi_pwd_ctl driver loaded
<4>[    0.540000] tcc_cm3_probe
<4>[    0.540000] UMP: UMP device driver r5p0-01rel0 loaded
<4>[    0.540000] Mali: Inserting Mali v600 device driver.
<4>[    0.540000] Mali: Compiled: Sep 27 2017, time: 10:12:41.
<4>[    0.540000] Mali: Driver revision: r5p0-01rel0
<4>[    0.540000] Mali: Mali device driver loaded
<6>[    0.560000] loop: module loaded
<6>[    0.560000] [pcm_select] pcm_select_init
<6>[    0.560000] [pcm_select] pcm_select_probe
<6>[    0.560000] [pcm_select] pcm_select_probe pcm_select driver registered
<4>[    0.560000] tcc_spi_init
<4>[    0.560000] tcc_spi_probe:[gpsb0]
<4>[    0.560000] tcc-spi0: init[0]
<4>[    0.560000] tcc_spi_probe:[gpsb2]
<4>[    0.560000] tcc-spi1: init[0]
<4>[    0.560000] [tsif_ex_init:1158] major number = 248
<4>[    0.560000] tcc893x_tsif : static dma buffer alloc @0xFFB00000(Phy=0x9F200000), size:1880000
<4>[    0.580000] tcc893x_tsif : static dma sec buffer alloc @0xFFD00000(Phy=0x9EC00000), size:524288
<4>[    0.580000] tsif_drv_probe:[gpsb1][107]
<6>[    0.580000] tun: Universal TUN/TAP device driver, 1.6
<6>[    0.580000] tun: (C) 1999-2004 Max Krasnyansky
<6>[    0.580000] usbcore: registered new interface driver asix
<6>[    0.580000] usbcore: registered new interface driver cdc_ether
<6>[    0.580000] usbcore: registered new interface driver net1080
<6>[    0.580000] usbcore: registered new interface driver cdc_subset
<6>[    0.580000] usbcore: registered new interface driver zaurus
<6>[    0.580000] usbcore: registered new interface driver cdc_ncm
<6>[    0.580000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
<6>[    0.630000] tcc-ehci tcc-ehci: Telechips EHCI HS
<6>[    0.630000] tcc-ehci tcc-ehci: new USB bus registered, assigned bus number 1
<6>[    0.630000] tcc-ehci tcc-ehci: irq 81, io mem 0xf2200000
<6>[    0.650000] tcc-ehci tcc-ehci: USB 2.0 started, EHCI 1.00
<6>[    0.650000] hub 1-0:1.0: USB hub found
<6>[    0.650000] hub 1-0:1.0: 1 port detected
<3>[    0.650000] [1;36m usb_new_device(product=Telechips EHCI HS) CFG2=0x919e14c8, LCFG=0x42000c ;[0m
<6>[    0.650000] Initializing USB Mass Storage driver...
<6>[    0.650000] usbcore: registered new interface driver usb-storage
<6>[    0.650000] USB Mass Storage support registered.
<4>[    0.650000] TCC RTC, (c) 2012, Telechips
<4>[    0.650000] tcc_rtc: alarm irq 75
<4>[    0.650000] read time 2017/09/27 08:13:05
<4>[    0.650000] tcc_rtc_getalarm
<4>[    0.650000] read alarm 00 00/00/00 00:00:00
<6>[    0.650000] using rtc device, tcc-rtc, for alarms
<6>[    0.650000] tcc-rtc tcc-rtc.0: rtc core: registered tcc-rtc as rtc0
<6>[    0.660000] [LG GPS_RTC] rtc_get_datetime: 4 13 8 27 9 17
<6>[    0.660000] [LG GPS_RTC] rtc_get_datetime: [VLF]:0 [VDET]:0
<6>[    0.660000] [LG GPS_RTC]  rtc_dev_getalarm : call alarm!
<6>[    0.660000] for using external rx8803 /dev/rtc1 device
<6>[    0.660000] lg-rtc 5-0032: rtc core: registered lg-rtc as rtc1
<4>[    0.660000] i2c-core: driver [lg-rtc] using legacy suspend method
<4>[    0.660000] i2c-core: driver [lg-rtc] using legacy resume method
<6>[    0.660000] [ GPS_RTC DEV] gps_rtc_dev_probe
<6>[    0.660000] i2c /dev entries driver
<6>[    0.670000] lg-charger 6-0054: succeeded to get SWITCH_REG(ba)
<4>[    0.670000] i2c-core: driver [lg-charger] using legacy suspend method
<4>[    0.670000] i2c-core: driver [lg-charger] using legacy resume method
<6>[    0.670000] [CHARGER DEV] charger_dev_init
<6>[    0.670000] Linux video capture interface: v2.00
<6>[    0.670000] TCCXXX Camera driver initializing
<4>[    0.670000] Camera Feature is alive!
<6>[    0.670000] tccxxx-camera: registered device video0 [v4l2]
<6>[    0.670000] _______cam_i2c_probe() :  cam_i2c_client = 0xdf9c2600
<6>[    0.670000] device-mapper: uevent: version 1.0.3
<6>[    0.670000] device-mapper: ioctl: 4.21.0-ioctl (2011-07-06) initialised: [email protected]
<6>[    0.670000] Bluetooth: HCI UART driver ver 2.2
<6>[    0.670000] Bluetooth: HCI H4 protocol initialized
<6>[    0.670000] Bluetooth: HCI BCSP protocol initialized
<6>[    0.670000] Bluetooth: HCIATH3K protocol initialized
<6>[    0.670000] [DS id:0] kern emmc str 0 ~ 3 => (2)
<6>[    0.680000] [DS id:0] kern emmc str 0 ~ 3 => (2)
<4>[    0.680000] tcc-sdhc: SDHC0 init
<4>[    0.680000] [mmc] tcc8930_mmc_switch_voltage, Down SD30 voltage from 3.3V to 1.8V...
<4>[    0.780000] ko/eu_ecn micron's cid.prv is 0x13
<4>[    0.790000] [mmc_init_card] max_dtr is 48000000.
<4>[    0.790000] [tcc_mmc] Start DDR clock...
<6>[    0.790000] mmc0: new high speed DDR MMC card at address 0001
<6>[    0.810000] mmcblk0: mmc0:0001 P1XXXX 3.60 GiB
<6>[    0.810000] mmcblk0boot0: mmc0:0001 P1XXXX partition 1 16.0 MiB
<6>[    0.810000] mmcblk0boot1: mmc0:0001 P1XXXX partition 2 16.0 MiB
<6>[    0.810000]  mmcblk0: p1 p2 p3 p4 < p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 >
<4>[    0.820000] [tcc_mmc] Broadcom WiFi is enabled at id no.1
<6>[    0.820000] [DS id:1] kern sd30 str 0 ~ 3 => (3)
<4>[    0.820000] tcc-sdhc: SDHC1 init
<6>[    0.820000]  mmcblk0boot1: unknown partition table
<6>[    0.820000] [DS id:2] kern sdc str 0 ~ 3 => (3)
<6>[    0.830000]  mmcblk0boot0: unknown partition table
<6>[    0.830000] [DS id:1] kern sd30 str 0 ~ 3 => (3)
<4>[    0.830000] tcc-sdhc: SDHC2 init
<6>[    0.830000] usbcore: registered new interface driver usbhid
<6>[    0.830000] usbhid: USB HID core driver
<6>[    0.830000] logger: created 256K log 'log_main'
<6>[    0.830000] logger: created 256K log 'log_events'
<6>[    0.830000] logger: created 256K log 'log_radio'
<6>[    0.840000] logger: created 256K log 'log_system'
<6>[    0.840000] logger: created 256K log 'log_tms'
<6>[    0.840000] usbcore: registered new interface driver snd-usb-audio
<6>[    0.840000] usbcore: registered new interface driver snd-usb-caiaq
<4>[    0.840000] tcc_iec958_probe()   ret: 0
<4>[    0.840000] [snd_card_create] telechips sound card
<4>[    0.840000] [snd_card_create] index sound card : 0
<6>[    0.890000] [DS id:1] kern sd30 str 0 ~ 3 => (3)
<6>[    0.950000] [DS id:1] kern sd30 str 0 ~ 3 => (3)
<6>[    0.990000] asoc: nxp-hifi <-> tcc-dai-i2s mapping ok
<6>[    1.010000] [DS id:1] kern sd30 str 0 ~ 3 => (3)
<6>[    1.080000] [DS id:2] kern sdc str 0 ~ 3 => (3)
<6>[    1.100000] asoc: IEC958 <-> tcc-dai-spdif mapping ok
<6>[    1.160000] [DS id:2] kern sdc str 0 ~ 3 => (3)
<6>[    1.210000] asoc: nxp-hifi-ch1 <-> tcc-dai-i2s-ch1 mapping ok
<6>[    1.240000] [DS id:2] kern sdc str 0 ~ 3 => (3)
<6>[    1.320000] asoc: IEC958 <-> tcc-dai-spdif-ch1 mapping ok
<6>[    1.320000] [DS id:2] kern sdc str 0 ~ 3 => (3)
<6>[    1.320000] ALSA device list:
<6>[    1.320000]   #0: Telechips Board
<6>[    1.320000] GACT probability NOT on
<6>[    1.320000] Mirror/redirect action on
<6>[    1.320000] u32 classifier
<6>[    1.320000]     Actions configured
<6>[    1.320000] Netfilter messages via NETLINK v0.30.
<6>[    1.320000] nf_conntrack version 0.5.0 (13153 buckets, 52612 max)
<6>[    1.320000] ctnetlink v0.93: registering with nfnetlink.
<6>[    1.320000] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[    1.320000] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[    1.320000] xt_time: kernel timezone is -0000
<6>[    1.320000] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[    1.320000] arp_tables: (C) 2002 David S. Miller
<6>[    1.320000] TCP cubic registered
<6>[    1.320000] NET: Registered protocol family 10
<6>[    1.320000] Mobile IPv6
<6>[    1.320000] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[    1.320000] IPv6 over IPv4 tunneling driver
<6>[    1.320000] NET: Registered protocol family 17
<6>[    1.320000] NET: Registered protocol family 15
<3>[    1.320000] Bluetooth: Can't register RFCOMM TTY driver
<6>[    1.320000] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[    1.320000] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[    1.320000] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
<6>[    1.320000] ThumbEE CPU extension supported.
<4>[    1.330000] tcc_hue_table_alloc 0xdf1c0000 size :131072
<6>[    1.330000] console [fb_virt-1] enabled
<4>[    1.330000] [## BT ##] init_module
<4>[    1.330000] read time 2017/09/27 08:13:05
<6>[    1.330000] tcc-rtc tcc-rtc.0: setting system clock to 2017-09-27 08:13:05 UTC (1506499985)
<6>[    1.330000] Freeing init memory: 172K
<4>[    1.350000] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
<11>[    1.480000] init: load_misc_properties_from_partition: misc.lge.log.klog=/data/system/klog
<11>[    1.480000] init: load_misc_properties_from_partition: misc.lge.log.dumpstate=/data/system/dump
<11>[    1.480000] init: load_misc_properties_from_partition: misc.log.hiddenconsole=off
<11>[    1.480000] init: load_misc_properties_from_partition: misc.upgrade.blk=
<11>[    1.480000] init: load_misc_properties_from_partition: misc.version.pos=05.08.05
<11>[    1.480000] init: load_misc_properties_from_partition: misc.hvac.checkdisp=0
<11>[    1.480000] init: load_misc_properties_from_partition: misc.version.primarykey=14
<11>[    1.480000] init: load_misc_properties_from_partition: misc.version.buyer=00
<11>[    1.480000] init: load_misc_properties_from_partition: misc.version.cartype=14
<11>[    1.480000] init: load_misc_properties_from_partition: misc.configuration.carType=AE_PHEV
<6>[    1.710000] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: (null)
<6>[    1.740000] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<6>[    1.860000] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
<6>[    1.870000] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<6>[    1.950000] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: resuid=1000,nomblk_io_submit,errors=panic
<6>[    1.960000] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<6>[    2.030000] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
<6>[    2.040000] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<6>[    2.110000] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
<3>[    2.250000] [1;36m tcc_xhci_phy_set() CFG2=0x119f9fc8 0x0=get_usb_clock_status()[0m
<4>[    2.250000] [1;33mXHCI USB 3.0 Mode Support (PCFG2=0x119f9fc8)  [0m
<6>[    2.250000] tcc-xhci tcc-xhci: Telechips XHCI HS
<6>[    2.250000] tcc-xhci tcc-xhci: new USB bus registered, assigned bus number 2
<6>[    2.250000] tcc-xhci tcc-xhci: irq 80, io mem 0xf2000000
<6>[    2.250000] hub 2-0:1.0: USB hub found
<6>[    2.250000] hub 2-0:1.0: 1 port detected
<3>[    2.250000] [1;36m usb_new_device(product=Telechips XHCI HS) CFG2=0x119f9fc8, LCFG=0x86420013 ;[0m
<6>[    2.250000] tcc-xhci tcc-xhci: new USB bus registered, assigned bus number 3
<6>[    2.250000] hub 3-0:1.0: USB hub found
<6>[    2.250000] hub 3-0:1.0: 1 port detected
<3>[    2.260000] [1;36m usb_new_device(product=Telechips XHCI HS) CFG2=0x119f9fc8, LCFG=0x86420013 ;[0m
<6>[    2.290000] file system registered
<6>[    2.300000]  gadget: Mass Storage Function, version: 2009/09/11
<6>[    2.300000]  gadget: Number of LUNs=2
<6>[    2.300000]  lun0: LUN: removable file: (no medium)
<6>[    2.300000]  lun1: LUN: removable file: (no medium)
<4>[    2.300000] giap2_port_alloc initializaing port: 0
<6>[    2.300000] ncm_function_init MAC: 00:00:00:00:00:00
<4>[    2.300000]  gadget: using random self ethernet address
<4>[    2.300000]  gadget: using random host ethernet address
<6>[    2.300000] ncm0: MAC f2:94:1a:4d:78:7a
<6>[    2.300000] ncm0: HOST MAC 52:3b:fa:94:79:13
<6>[    2.300000]  gadget: android_usb ready
<6>[    2.340000] ADDRCONF(NETDEV_UP): ncm0: link is not ready
<3>[    2.480000] android_usb: already disabled
<6>[    2.480000] android_usb: enabled 'iap2' (0)
<6>[    2.480000] android_usb: enabled 'ncm' (0)<4>[    2.520000] texfat: module license 'Commercial. For support email [email protected]' taints kernel.
<4>[    2.520000] Disabling lock debugging due to kernel taint
<4>[    2.530000] <6>Tuxera exFAT driver version 3015.1.29.8 [Flags: R/W MODULE].
<4>[    2.530000] <6>Built against headers 3.1.10-tcc #273 SMP PREEMPT Tue Nov 11 16:34:39 KST 2014 arm
<4>[    2.530000] <6>Running on kernel 3.1.10-tcc #2 SMP PREEMPT Wed Sep 27 16:34:59 KST 2017 armv7l
<4>[    2.540000] <6>Tuxera NTFS driver 3015.1.29.24 [Flags: R/W MODULE].
<4>[    2.570000] <5>ufsd:: trace mask set to 0000000f
<4>[    2.570000] <5>ufsd: driver (lke_9.0.0 ufsd_bug_69240_telechip_r235147_b9, LBD=ON, acl, ioctl, bdi, sd(0), fua, bz, tr) loaded at bf11c000
<4>[    2.570000] NTFS support included
<4>[    2.570000] optimized: speed
<4>[    2.570000] Build_for__tcc_android_4.x_k3.1.10_avn_2014-09-04_ufsd_bug_69240_telechip_r235147_b9
<4>[    2.570000]
<4>[    2.570000] <5>ufsdAuthentication is complete !!
<4>[    2.680000] ============> VPU Devices drivers initializing!!
<3>[    2.700000] dwc3 dwc3.0:  init:: request df879480 was not queued to ep0out
<3>[    2.700000] android_usb: already disabled
<6>[    2.700000] android_usb: enabled 'iap2' (0)
<6>[    2.700000] android_usb: enabled 'ncm' (0)<6>[    7.720000] warning: `zygote' uses 32-bit capabilities (legacy support in use)
<6>[    9.940000] request_suspend_state: wakeup (3->0) at 9941312255 (2017-09-27 08:13:14.100741170 UTC)
<6>[   10.480000] acc_open
<6>[   10.480000] acc_release
<4>[   10.620000] LGD LA070WV7-SL01 LVDS driver lge7wvlcd_set_backlight_level, backlight level:102
<12>[   11.830000] [FASTBOOT] Run /system/vendor/bin/fastboot_suspend service
<12>[   13.080000] [FASTBOOT] go hibernation
<6>[   13.080000] xres:800, yres:480
<6>[   13.080000] line_length:3200, bits_per_pixel:32
<12>[   25.190000] [FASTBOOT] CHK: persist.sys.usb.config=iap2,ncm
<12>[   25.190000] [FASTBOOT] CHK: sys.usb.config=iap2,ncm
<12>[   25.200000] [FASTBOOT] CHK: ro.product.model=TCC893X_EVM
<12>[   25.210000] [FASTBOOT] CHK: ro.build.fingerprint=LGE/koecn/koecn:4.2.2/JDQ39/user.dagyeong.20170927.163547:user/release-keys
<12>[   25.210000] [FASTBOOT] CHK: ro.lge.sw_version=XX.EUR.SOP.00.005.3
<12>[   25.220000] [FASTBOOT] CHK: ro.lge.ivimodel=1
<12>[   25.220000] [FASTBOOT] CHK: misc.version.hwmicom=12
<12>[   25.230000] [FASTBOOT] CHK: misc.version.micom=00.05.222
<12>[   25.240000] [FASTBOOT] CHK: misc.configuration.carType=AE_PHEV
<12>[   25.240000] [FASTBOOT] start to compress '/data'
<12>[   25.250000] bsdtar: Removing leading '/' from member names
<12>[   25.810000] [FASTBOOT] compress RESULT: '0'
<12>[   25.820000] [FASTBOOT] /mnt/secure/wrs_ss_data0.tar.gz size: (184 KB)
<12>[   25.890000] [FASTBOOT] decompress RESULT: 0
<12>[   25.910000] [FASTBOOT] delete /mnt/secure/data
<12>[   25.920000] PM_HIBERNATION_PREPARE:  PM_HIBERNATION_PREPARE
<6>[   25.920000] PM: Basic memory bitmaps created
<6>[   25.920000] PM: Syncing filesystems ... done.
<4>[   25.930000] Freezing user space processes ... (elapsed 0.01 seconds) done.
<4>[   25.950000] Freezing remaining freezable tasks ... (elapsed 0.01 seconds) done.
<12>[   25.970000] PM_POST_FREEZE_PROCESS:  PM_POST_FREEZE_PROCESS
<12>[   25.970000] PM_POST_FREEZE_PROCESS:  start to compress '/data'
<12>[   25.980000] bsdtar: Removing leading '/' from member names
<12>[   26.380000] PM_POST_FREEZE_PROCESS:  compress RESULT: '0'
<12>[   26.390000] PM_POST_FREEZE_PROCESS:  /mnt/secure/wrs_ss_data.tar.gz size: (184 KB)
<12>[   26.460000] PM_POST_FREEZE_PROCESS:   RESULT: 0
<12>[   26.480000] PM_POST_FREEZE_PROCESS:  delete /mnt/secure/data
<12>[   26.490000] PM_POST_FREEZE_PROCESS:  delete /mnt/secure/wrs_ss_data0.tar.gz
<6>[   26.490000] PM:FS: save inotify user [/data/system/users/0]
<6>[   26.490000] PM:FS: save inotify user [/data/app-private]
<6>[   26.490000] PM:FS: save inotify user [/data/app]
<6>[   26.490000] PM:FS: save inotify user [/cache]
<6>[   26.490000] PM:FS: move task [keystore] on pwd:/data/misc/keystore to /dev/wrs_ss_safe/
<6>[   26.490000] PM:FS: save partition [/ivilog:/dev/block/platform/bdm/by-num/p16]
<6>[   26.540000] PM:FS: save partition [/ivibackup:/dev/block/platform/bdm/by-num/p15]
<6>[   26.570000] PM:FS: save partition [/data:/dev/block/platform/bdm/by-num/p3]
<6>[   26.620000] PM:FS: save partition [/cache:/dev/block/platform/bdm/by-num/p5]
<6>[   26.650000] PM: Preallocating image memory... done (allocated 58094 pages)
<6>[   26.780000] PM: Allocated 232376 kbytes in 0.13 seconds (1787.50 MB/s)
<4>[   26.780000]
<4>[   26.780000]  tccxxx_scaler0_drv:  Suspend In.
<4>[   26.780000]
<4>[   26.780000]  tccxxx_scaler0_drv:  Suspend Out.
<4>[   26.790000] tca_fb_suspend:
<6>[   26.790000] [LG GPS_RTC]  gps_rtc_suspend : called
<6>[   26.800000] [ GPS_RTC DEV] gps_rtc_dev_suspend
<6>[   26.820000] [pcm_select] pcm_select_suspend
<6>[   26.830000] ##### [tcc i2s.1 suspend in] #####
<6>[   26.840000] ##### [tcc i2s.1 suspend out] #####
<6>[   26.850000] ##### [tcc i2s.0 suspend in] #####
<6>[   26.870000] ##### [tcc i2s.0 suspend out] #####
<4>[   26.880000] [## BT ##] tcc_bluetooth_suspend
<6>[   26.890000] [RTCCON] : 0x00000000
<6>[   26.900000] [iNTCON] : 0x00000000
<6>[   26.920000] [RTCALM] : 0x00000000
<6>[   26.930000] [RTCIM ] : 0x00000000
<3>[   27.000000] tcc-uart.8: ttyTCC8: Unable to drain transmitter
<6>[   27.020000] PM: freeze of devices complete after 240.566 msecs
<6>[   27.030000] PM: late freeze of devices complete after 0.344 msecs
<4>[   27.520000] Disabling non-boot CPUs ...
<4>[   27.540000] stop_machine_cpu_stop smp=1
<4>[   27.540000] stop_machine_cpu_stop smp=0
<5>[   27.570000] CPU1: shutdown
<6>[   27.580000] PM: Creating hibernation image:
<6>[   27.580000] PM: Need to copy 57704 pages
<6>[   27.580000] l2x0 already ON - ID:410000C6, Type:9E240240, Ctrl:00000001, AUX:72150001
<6>[   27.580000] Enabling non-boot CPUs ...
<4>[   27.590000] Before waking up the secondary cpu(1), SEC_CPU_START_CFG value is 0
<4>[   27.590000] CPU1: Booted secondary processor
<2>[   27.590000] CPU1: Unknown IPI message 0x1
<6>[   27.590000] CPU1 is up
<6>[   27.590000] PM: early restore of devices complete after 0.303 msecs
<6>[   27.600000] Switched to NOHz mode on CPU #1
<6>[   27.650000] TCC RTC resume In !!!!!
<6>[   27.650000] TCC RTC resume Out !!!!!
<4>[   27.700000] usb usb1: root hub lost power or was reset
<3>[   27.700000] [1;36m tcc_xhci_phy_set() CFG2=0x119f9fc8 0x0=get_usb_clock_status()[0m
<3>[   27.700000] [1;36m wait_phy_clock_valid() TCC SOC may be out of order cnt=1002 [0m
<4>[   27.700000] [1;33mXHCI USB 3.0 Mode Support (PCFG2=0x119f9fc8)  [0m
<4>[   27.700000] usb usb2: root hub lost power or was reset
<4>[   27.700000] usb usb3: root hub lost power or was reset
<4>[   27.700000] [## BT ##] tcc_bluetooth_resume
<6>[   27.700000] ram_console: uncorrectable error in header
<3>[   27.700000] ram_console_resume 0xe18bc51c
<6>[   27.700000] ram_console: no valid data in buffer (sig = 0xe18bc51c)
<6>[   27.700000] ##### [tcc i2s.0 resume in] #####
<6>[   27.700000] ##### [tcc i2s.0 resume out] #####
<6>[   27.700000] ##### [tcc i2s.1 resume in] #####
<6>[   27.700000] ##### [tcc i2s.1 resume out] #####
<6>[   27.700000] [pcm_select] pcm_select_resume
<6>[   27.700000] [ GPS_RTC DEV] gps_rtc_dev_resume
<6>[   27.700000] [LG GPS_RTC]  gps_rtc_resume : called
<6>[   27.700000] lg-charger 6-0054: lk already set SWITCH_REG(ba)
<4>[   27.700000] tca_fb_resume:
<6>[   27.700000] [DS id:0] kern emmc str 0 ~ 3 => (2)
<4>[   27.760000] ko/eu_ecn micron's cid.prv is 0x13
<4>[   27.770000] [mmc_init_card] max_dtr is 48000000.
<4>[   27.770000] [tcc_mmc] Start DDR clock...
<4>[   27.770000] [## BT ##] tcc_bt_rfkill_set_power POWER_ON [0]
<4>[   27.880000]
<4>[   27.880000]  tccxxx_scaler0_drv:  Resume Out.
<6>[   27.880000] PM: restore of devices complete after 228.728 msecs
<6>[   27.880000] Board Revision : 05.00
<12>[   27.880000] PM_THAW_PROCESS_PREPARE:  PM_THAW_PROCESS_PREPARE
<12>[   27.890000] PM_THAW_PROCESS_PREPARE:  FSCK /data
<6>[   27.920000] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro,resuid=1000
<12>[   28.010000] PM_THAW_PROCESS_PREPARE:  FSCK /ivilog
<6>[   28.020000] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<12>[   28.080000] PM_THAW_PROCESS_PREPARE:  FSCK /ivibackup
<6>[   28.090000] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<6>[   28.160000] PM:FS: restore mount [/cache:/dev/block/platform/bdm/by-num/p5]
<6>[   28.170000] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
<6>[   28.170000] PM:FS: restore mount [/data:/dev/block/platform/bdm/by-num/p3]
<6>[   28.180000] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: resuid=1000,nomblk_io_submit,errors=panic
<6>[   28.180000] PM:FS: restore mount [/ivibackup:/dev/block/platform/bdm/by-num/p15]
<6>[   28.180000] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
<6>[   28.190000] PM:FS: restore mount [/ivilog:/dev/block/platform/bdm/by-num/p16]
<6>[   28.200000] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=panic
<6>[   28.200000] PM:FS: restore inotify user [/cache]
<6>[   28.210000] PM:FS: restore inotify user [/data/app]
<6>[   28.210000] PM:FS: restore inotify user [/data/app-private]
<6>[   28.210000] PM:FS: restore inotify user [/data/system/users/0]
<4>[   28.210000] Restarting tasks ... done.
<4>[   28.230000]
<4>[   28.230000]  [tcc_mmc_aboot_set_property] ... flag = 0
<6>[   28.230000] [DS id:2] kern sdc str 0 ~ 3 => (3)
<12>[   28.230000] PM_POST_HIBERNATION:  PM_POST_HIBERNATION
<12>[   28.250000] [FASTBOOT] Run /system/vendor/bin/fastboot_resume service
<12>[   28.260000] insmod /lib/modules/atmel_mxt540e.ko
<12>[   28.270000] [FASTBOOT] CHK: persist.sys.usb.config=iap2,ncm
<6>[   28.270000] mxt540_ts 2-004c: [TSP] maXTouch driver(mxt540_ts), addr:004c, irq:37
<12>[   28.280000] [FASTBOOT] CHK: sys.usb.config=iap2,ncm
<12>[   28.290000] [FASTBOOT] CHK: sys.usb.mode=usb_host
<11>[   28.390000] init: load_misc_properties_from_partition: misc.lge.log.klog=/data/system/klog
<11>[   28.390000] init: load_misc_properties_from_partition: misc.lge.log.dumpstate=/data/system/dump
<11>[   28.390000] init: load_misc_properties_from_partition: misc.log.hiddenconsole=off
<11>[   28.390000] init: load_misc_properties_from_partition: misc.upgrade.blk=
<11>[   28.390000] init: load_misc_properties_from_partition: misc.version.pos=05.08.05
<11>[   28.390000] init: load_misc_properties_from_partition: misc.hvac.checkdisp=2
<11>[   28.400000] init: load_misc_properties_from_partition: misc.version.primarykey=14
<11>[   28.400000] init: load_misc_properties_from_partition: misc.version.buyer=00
<11>[   28.400000] init: load_misc_properties_from_partition: misc.version.cartype=20
<11>[   28.400000] init: load_misc_properties_from_partition: misc.configuration.carType=AE_EV
<3>[   28.400000] dwc3 dwc3.0:  init:: request df879480 was not queued to ep0out
<3>[   28.400000] android_usb: already disabled
<6>[   28.400000] android_usb: enabled 'iap2' (0)
<6>[   28.400000] android_usb: enabled 'ncm' (0)[FASTBOOT] CHK: persist.sys.usb.config=iap2,ncm
<12>[   28.430000] [FASTBOOT] CHK: sys.usb.config=iap2,ncm
<12>[   28.430000] [FASTBOOT] CHK: sys.usb.mode=usb_host
<12>[   28.430000] [FASTBOOT] Start micomd
<4>[   28.450000] [mxt_probe] reset done !!!
<6>[   28.460000] input: mxt540_ts as /devices/platform/tcc-i2c.2/i2c-2/2-004c/input/input0
<4>[   28.550000] [tcc_mmc] New card is inserted without write protect mode.
<6>[   28.550000] mmc2: new SDHC card at address 59b4
<6>[   28.560000] mmcblk1: mmc2:59b4 HDMNS 29.8 GiB
<6>[   28.560000]  mmcblk1: p1
<3>[   28.610000] mxt540_ts 2-004c: [TSP] maXTouch chip reset[rewrite orient]!!!
<6>[   29.110000] [LG GPS_RTC] rtc_get_datetime: 57 40 8 24 1 18
<6>[   29.160000] [LG GPS_RTC] rtc_get_datetime: [VLF]:0 [VDET]:0
<6>[   29.240000] [LG GPS_RTC] rtc_get_datetime: 57 40 8 24 1 18
<6>[   29.240000] [LG GPS_RTC] rtc_get_datetime: [VLF]:0 [VDET]:0
<6>[   29.330000] [LG GPS_RTC] rtc_get_datetime: 57 40 8 24 1 18
<6>[   29.330000] [LG GPS_RTC] rtc_get_datetime: [VLF]:0 [VDET]:0
<4>[   29.480000] tca_spi_set_port:channel[0]port[5]
<4>[   29.720000] lut_open :  1'th.
<4>[   29.720000] TCC LUT: sin : 0, cos : 1000, saturation : 10
<4>[   29.720000] tcc_sw_hue_table_set   saturation:10 v_sin:0 v_cos:1000
<4>[   29.770000] TCC LUT: lut_release:  0'th.
<4>[   29.770000] lut_open :  1'th.
<6>[   29.940000] [LG GPS_RTC] rtc_get_datetime: 58 40 8 24 1 18
<6>[   29.960000] [LG GPS_RTC] rtc_get_datetime: [VLF]:0 [VDET]:0
<4>[   29.960000] set time 2018/01/24 08:40:58
<3>[   29.990000] mxt540_ts 2-004c: store_orient()[3090] : lcd type(8) inch
<6>[   32.660000] tcc_cm3_ctrl_open::373
<4>[   32.660000] tcc_cm3_ctrl_ioctl cmd: 1, arg: becac588
<4>[   32.660000] cortex-m3 : clk_get_rate 100000000
<4>[   32.660000] tcc_cm3_ctrl_ioctl cmd: 3, arg: becac588
<4>[   32.660000] cm3_cmd:   iOpCode = 0x75, pParam1 = 0xff, pParam2 = 0xff.
<4>[   32.770000] cm3_cmd_status = 0, ret = 100
<4>[   32.770000] tcc_cm3_ctrl_ioctl cmd: 3, arg: becac588
<4>[   32.770000] cm3_cmd:   iOpCode = 0x71, pParam1 = 0xff, pParam2 = 0xff.
<4>[   32.880000] cm3_cmd_status = 0, ret = 100
<6>[   32.880000] tcc_cm3_ctrl_release::367
<6>[   32.880000] tcc_cm3_ctrl_open::373
<4>[   32.880000] tcc_cm3_ctrl_ioctl cmd: 3, arg: becac598
<4>[   32.880000] cm3_cmd:   iOpCode = 0x72, pParam1 = 0xff, pParam2 = 0xff.
<4>[   32.990000] cm3_cmd_status = 0, ret = 100
<4>[   33.350000] !@#---- CM3_AVN_Proc - SET_EARLY_CAMERA_STOP = 0x0
<4>[   33.350000] tcc_rear_camera_display() - start
<4>[   33.350000] tcc_rear_camera_display() - end
<4>[   33.350000] tcc_rear_camera_stop() - start
<11>[   33.610000] init: property_set: misc : misc.btdut, 0
<11>[   33.610000] init: write_btsi_property: misc : misc.btdut, 0
<4>[   33.620000] ioreg_spin_lock_irqsave *** irq_count = 0
<4>[   33.620000] tcc_rear_camera_stop() - end
<4>[   33.630000] tcc_cm3_ctrl_ioctl cmd: 0, arg: becac598
<6>[   33.630000] tcc_cm3_ctrl_release::367
<11>[   33.810000] init: property_set: misc : misc.upgrade.mode, none
<11>[   33.810000] init: write_btsi_property: misc : misc.upgrade.mode, none
<4>[   35.330000] set time 2018/01/24 08:41:04
<6>[   35.330000] [LG GPS_RTC] rtc_get_datetime: 3 41 8 24 1 18
<6>[   35.340000] [LG GPS_RTC] rtc_get_datetime: [VLF]:0 [VDET]:0
<6>[   35.340000] [LG GPS_RTC] rtc_set_datetime: 4 41 8 24 1 18
<6>[   35.390000] [LG GPS_RTC] rtc_get_datetime: 4 41 8 24 1 18
<6>[   35.390000] [LG GPS_RTC] rtc_get_datetime: [VLF]:0 [VDET]:0
<4>[   35.880000] dhd_module_init in
<4>[   35.880000] found wifi platform device bcmdhd_wlan
<4>[   35.880000] Power-up adapter 'DHD generic adapter'
<4>[   35.880000] wifi_platform_set_power = 1
<4>[   35.880000] [tcc_wifi_set_power] onoff : 1
<4>[   35.940000] wifi_platform_bus_enumerate device present 1
<4>[   35.940000] tcc_wifi_set_carddetect: 1
<4>[   35.940000] [tcc_sdio_status_notify_cb] mmc1: card_present 1
<4>[   35.940000] [tcc_sdio_status_notify_cb] mmc1: Slot status change detected (0 -> 1)
<6>[   35.940000] [DS id:1] kern sd30 str 0 ~ 3 => (3)
<4>[   35.990000] [mmc] MMC_CAP_UHS_SDR50 is enabled.
<4>[   35.990000] [mmc] tcc8930_mmc_switch_voltage, Down SD30 voltage from 3.3V to 1.8V...
<4>[   36.130000] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
<4>[   36.140000] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
<4>[   36.140000] mmc1: queuing unknown CIS tuple 0x80 (6 bytes)
<4>[   36.230000] [mmc] tcc_mmc_select_drive_strength, SD_DRIVER_TYPED_C is supported.
<4>[   36.230000] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
<6>[   36.230000] mmc1: new ultra high speed SDIO card at address 0001
<4>[   36.270000] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
<6>[   36.280000] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xdd6a13f0
<4>[   36.290000] p2p0: P2P Interface Registered
<4>[   36.290000] dhd_deferred_work_init: work queue initialized
<4>[   36.980000] [## BT ##] tcc_bt_rfkill_set_power POWER_OFF [1]
<4>[   37.080000] dhdsdio_write_vars dhdsdio_membytes end size : 184
<4>[   37.080000] dhdsdio_write_vars dhdsdio_membytes ok..2232
<4>[   37.100000] [## BT ##] tcc_bt_rfkill_set_power POWER_ON [0]
<4>[   37.230000] [## BT ##] tcc_bt_dev_open
<4>[   37.230000] [## BT ##] tcc_bt_dev_ioctl cmd[ea69] arg[604a7c64]
<4>[   37.230000] [## BT ##] tcc_bt_dev_release
<4>[   37.320000]
<4>[   37.320000] Dongle Host Driver, version 1.141.67 (r)
<4>[   37.320000] Compiled from
<4>[   37.330000] Register interface [wlan0]  MAC: xx:xx:xx:xx:xx:xx
<4>[   37.330000]
<4>[   37.690000] wl_cfg80211_scan !!!
<4>[   44.110000] wl_cfg80211_scan !!!
<4>[   45.540000] net_ratelimit: 8 callbacks suppressed
<6>[   45.540000] CFG80211-ERROR) wl_inform_bss : scanned AP count (5)
<6>[   46.080000] mxt540_ts 2-004c: (0)good(11630)
<7>[   47.950000] wlan0: no IPv6 routers present
<4>[   50.550000] wl_cfg80211_scan !!!
<6>[   51.980000] CFG80211-ERROR) wl_inform_bss : scanned AP count (5)
<4>[   56.990000] wl_cfg80211_scan !!!
<6>[   58.430000] CFG80211-ERROR) wl_inform_bss : scanned AP count (5)
<4>[   63.430000] wl_cfg80211_scan !!!
<6>[   64.870000] CFG80211-ERROR) wl_inform_bss : scanned AP count (4)
<4>[   69.870000] wl_cfg80211_scan !!!
<6>[   71.310000] CFG80211-ERROR) wl_inform_bss : scanned AP count (5)
<4>[   76.320000] wl_cfg80211_scan !!!
<6>[   77.760000] CFG80211-ERROR) wl_inform_bss : scanned AP count (4)
<4>[   82.770000] wl_cfg80211_scan !!!
<6>[   84.200000] CFG80211-ERROR) wl_inform_bss : scanned AP count (2)
<4>[   89.210000] wl_cfg80211_scan !!!
<6>[   90.650000] CFG80211-ERROR) wl_inform_bss : scanned AP count (5)
<4>[   95.660000] wl_cfg80211_scan !!!
<6>[   97.090000] CFG80211-ERROR) wl_inform_bss : scanned AP count (4)
<4>[  102.100000] wl_cfg80211_scan !!!
<6>[  103.530000] CFG80211-ERROR) wl_inform_bss : scanned AP count (4)
<4>[  108.540000] wl_cfg80211_scan !!!
<6>[  109.980000] CFG80211-ERROR) wl_inform_bss : scanned AP count (4)
<4>[  114.980000] wl_cfg80211_scan !!!
<6>[  116.430000] CFG80211-ERROR) wl_inform_bss : scanned AP count (5)
<4>[  121.430000] wl_cfg80211_scan !!!
<6>[  122.870000] CFG80211-ERROR) wl_inform_bss : scanned AP count (6)
<4>[  127.870000] wl_cfg80211_scan !!!
<6>[  129.310000] CFG80211-ERROR) wl_inform_bss : scanned AP count (6)
<4>[  134.320000] wl_cfg80211_scan !!!
<6>[  135.760000] CFG80211-ERROR) wl_inform_bss : scanned AP count (7)
<4>[  140.770000] wl_cfg80211_scan !!!
<6>[  142.210000] CFG80211-ERROR) wl_inform_bss : scanned AP count (6)
<4>[  147.210000] wl_cfg80211_scan !!!
<6>[  148.650000] CFG80211-ERROR) wl_inform_bss : scanned AP count (9)
<4>[  153.660000] wl_cfg80211_scan !!!
<6>[  155.100000] CFG80211-ERROR) wl_inform_bss : scanned AP count (14)
<4>[  160.100000] wl_cfg80211_scan !!!
<6>[  161.540000] CFG80211-ERROR) wl_inform_bss : scanned AP count (1)
<4>[  166.550000] wl_cfg80211_scan !!!
<6>[  167.980000] CFG80211-ERROR) wl_inform_bss : scanned AP count (0)
<4>[  172.990000] wl_cfg80211_scan !!!
<6>[  174.430000] CFG80211-ERROR) wl_inform_bss : scanned AP count (1)
<4>[  179.430000] wl_cfg80211_scan !!!
<6>[  180.870000] CFG80211-ERROR) wl_inform_bss : scanned AP count (1)
<4>[  185.880000] wl_cfg80211_scan !!!
<6>[  187.320000] CFG80211-ERROR) wl_inform_bss : scanned AP count (4)
<4>[  192.320000] wl_cfg80211_scan !!!
<6>[  193.770000] CFG80211-ERROR) wl_inform_bss : scanned AP count (2)
<4>[  198.770000] wl_cfg80211_scan !!!
<6>[  200.210000] CFG80211-ERROR) wl_inform_bss : scanned AP count (4)
<4>[  205.220000] wl_cfg80211_scan !!!
<6>[  206.660000] CFG80211-ERROR) wl_inform_bss : scanned AP count (22)
<4>[  211.670000] wl_cfg80211_scan !!!
<6>[  213.120000] CFG80211-ERROR) wl_inform_bss : scanned AP count (14)
<4>[  218.130000] wl_cfg80211_scan !!!
<6>[  219.600000] CFG80211-ERROR) wl_inform_bss : scanned AP count (19)
<4>[  224.620000] wl_cfg80211_scan !!!
<6>[  226.070000] CFG80211-ERROR) wl_inform_bss : scanned AP count (25)
<4>[  231.090000] wl_cfg80211_scan !!!
<6>[  232.530000] CFG80211-ERROR) wl_inform_bss : scanned AP count (20)
<4>[  237.540000] wl_cfg80211_scan !!!
<6>[  238.970000] CFG80211-ERROR) wl_inform_bss : scanned AP count (16)
<4>[  243.980000] wl_cfg80211_scan !!!
<6>[  245.420000] CFG80211-ERROR) wl_inform_bss : scanned AP count (6)
<4>[  250.430000] wl_cfg80211_scan !!!
<6>[  252.040000] CFG80211-ERROR) wl_inform_bss : scanned AP count (0)
<4>[  257.040000] wl_cfg80211_scan !!!
<6>[  258.480000] CFG80211-ERROR) wl_inform_bss : scanned AP count (1)
<4>[  263.490000] wl_cfg80211_scan !!!
<6>[  264.920000] CFG80211-ERROR) wl_inform_bss : scanned AP count (1)
<4>[  269.930000] wl_cfg80211_scan !!!
<6>[  271.360000] CFG80211-ERROR) wl_inform_bss : scanned AP count (3)
<6>[  271.430000] [LG GPS_RTC] rtc_get_datetime: 0 45 8 24 1 18
<6>[  271.430000] [LG GPS_RTC] rtc_get_datetime: [VLF]:0 [VDET]:0
<4>[  271.440000] set time 2018/01/24 08:45:00
<6>[  271.440000] [LG GPS_RTC] rtc_set_datetime: 0 45 8 24 1 18
<6>[  271.450000] [LG GPS_RTC] rtc_get_datetime: 0 45 8 24 1 18
<6>[  271.450000] [LG GPS_RTC] rtc_get_datetime: [VLF]:0 [VDET]:0
<4>[  276.370000] wl_cfg80211_scan !!!
<6>[  690.780000] CFG80211-ERROR) wl_cfg80211_connect : Connectting with xx:xx:xx:xx:xx:xx channel (10) ssid "xxxxxxxxx", len (10)
<6>[  690.780000]
<4>[  691.060000] wl_bss_connect_done succeeded with xx:xx:xx:xx:xx:xx
<4>[  691.120000] wl_bss_connect_done succeeded with xx:xx:xx:xx:xx:xx
<4>[  729.560000] == alsa-debug PCM CH0 == [set_dma_outbuffer], original len[32768]
<4>[  749.280000] [tcc_pcm_close] rate(48000) close pcm device, output interrupts[924]
<4>[  751.850000] == alsa-debug PCM CH0 == [set_dma_outbuffer], original len[32768]
<11>[  764.630000] init: property_set: misc : misc.sys.navi.lastmode, true
<11>[  764.630000] init: write_btsi_property: misc : misc.sys.navi.lastmode, true
<11>[  764.640000] init: misc.sys.navi.lastmode : ( old value:false, new value:true)
<4>[  767.520000] [tcc_pcm_close] rate(48000) close pcm device, output interrupts[733]
<4>[  789.380000] == alsa-debug PCM CH0 == [set_dma_outbuffer], original len[32768]
<11>[  791.310000] init: property_set: misc : misc.sys.navi.lastmode, false
<11>[  791.310000] init: write_btsi_property: misc : misc.sys.navi.lastmode, false
<11>[  791.310000] init: misc.sys.navi.lastmode : ( old value:true, new value:false)
<11>[  791.740000] init: property_set: misc : misc.sys.navi.lastmode, false
<11>[  791.740000] init: write_btsi_property: misc : misc.sys.navi.lastmode, false
<4>[  795.230000] [tcc_pcm_close] rate(48000) close pcm device, output interrupts[273]
<6>[ 1059.340000] usb 2-1: new high speed USB device number 2 using tcc-xhci
<3>[ 1059.340000] #############  msleep(10); new high speed USB device number 2 using tcc-xhci
<6>[ 1059.390000] scsi0 : usb-storage 2-1:1.0
<5>[ 1059.400000] scsi 0:0:0:0: Direct-Access              USB Flash Memory 1.04 PQ: 0 ANSI: 0 CCS
<4>[ 1059.400000] scsi target0:0:0: Unbalanced pm_runtime_enable!
<4>[ 1059.400000] scsi 0:0:0:0: Unbalanced pm_runtime_enable!
<5>[ 1059.400000] sd 0:0:0:0: Attached scsi generic sg0 type 0
<3>[ 1059.440000] [1;36m usb_new_device(product=USB Flash Memory) CFG2=0xf19f9f08, LCFG=0x86420013 ;[0m
<5>[ 1060.470000] sd 0:0:0:0: [sda] 499712 512-byte logical blocks: (255 MB/244 MiB)
<5>[ 1060.470000] sd 0:0:0:0: [sda] Write Protect is off
<7>[ 1060.470000] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
<3>[ 1060.470000] sd 0:0:0:0: [sda] No Caching mode page present
<3>[ 1060.470000] sd 0:0:0:0: [sda] Assuming drive cache: write through
<6>[ 1060.480000]  sda: sda1
<3>[ 1060.490000] sd 0:0:0:0: [sda] No Caching mode page present
<3>[ 1060.490000] sd 0:0:0:0: [sda] Assuming drive cache: write through
<5>[ 1060.490000] sd 0:0:0:0: [sda] Attached SCSI removable disk
<11>[ 1060.510000] init: property_set: misc : misc.usb.path, none
<11>[ 1060.510000] init: write_btsi_property: misc : misc.usb.path, none
<11>[ 1060.520000] init: misc.usb.path : ( old value:/dev/block/sda1 /storage/usb0/CAVNEU_H/upgrade.lgk, new value:none)
<11>[ 1060.570000] init: property_set: misc : misc.usb.path, /dev/block/sda1 /storage/usb0/CAVNEU_H/upgrade.lgk
<11>[ 1060.570000] init: write_btsi_property: misc : misc.usb.path, /dev/block/sda1 /storage/usb0/CAVNEU_H/upgrade.lgk
<11>[ 1060.570000] init: misc.usb.path : ( old value:none, new value:/dev/block/sda1 /storage/usb0/CAVNEU_H/upgrade.lgk)
on y trouve l'initialisation de la caméra par exemple...et quelques infos comme:
redhat
Tuxera
Android
ça vous inspire?
Très intéressante découverte Chris !
Donc exit QNX, c'est bien une version modée de Android qui tourne...
A noter le "modèle" : TCC893X_EVM
y a quelques pages intéressantes sur Google
redhat, tuxera, c'est juste dans les adresses e-mail pour joindre ceux qui ont fait tel ou tel driver.
C'est en effet le log de boot d'un noyau Linux, en l'occurrence a priori un android vu ce qu'on peut y lire...
Le processeur de cette bête est celui-ci :
https://www.telechips.com/eng/Product/consumer_pro17.asp
je suis d'accord, mais on a bien un noyau linux qui tourne sous redhat, et peut être des app tuxera peuvent être développées via leur SDK...?
Autre remarque: si vous mettez votre SD (de votre MAP) dans un lecteur vous trouverez un fichier apk à la racine de la carte.... pouvons nous signer des apk pour ajouter directement à la ioniq? (je ne suis pas dev Android, mais peut être quelqu'un va apporter la réponse)
autre info trouvée:
Build: LGE/koecn/koecn:4.2.2/JDQ39/user.dagyeong.20170927.163547:user/release-keys
Hardware: tcc893x_evm_emmc
Revision: 4096
Bootloader: unknown
Radio: unknown
Kernel: Linux version 3.1.10-tcc (dagyeong@cm03-c) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) )
on me dit dans l'oreillette : kernel 3.1.10 avec une surcouche Android
et ca tourne sur une "puce" TCC893X_EVM, et y a des liens intéressants dans Google
tout à fait (on postait les mêmes infos au même moment...les grands esprits se croisent )
Je ne comprends pas cette question.
Si ta question est « sous RedHat il y a bien un noyau Linux ? », ma réponse est « oui, mais aucun rapport avec ces logs ».
Si ta question est « ces logs montrent-ils qu'on est sur une Red Hat ? », ma réponse est « non, assurément non, ceci n'est pas une Red Hat ».
Je comprends encore moins cette question-là. Je ne sais pas comment je pourrais la comprendre, donc je ne peux pas faire des suppositions comme ci-dessus.
Je ne pense pas. J'imagine que le système ne va pas automatiquement charger n'importe quel apk qu'il va trouver sur la carte.
Mais je n'ai aucune certitude. Les gens qui arrivent à hacker ce type de systèmes, c'est à partir de ce genre ce logs-là qu'ils travaillent pour trouver ce qu'ils peuvent faire.
Et pourtant quand tu mets à jour la map (voir post adéquat) il y a une apk à la racine, et je pense que c'est elle que fait que la map se charge...Mais moi aussi je ne fais que des suppositions...C'est bien l'idée en lançant ce post, de débattre de tout ça
Ma soeur, qui connaît bien le domaine, me dit :
C'est donc un kernel 3.1.10, donc un vieux kernel, qui a priori est utilisé sur un Android 4.2 ou une version de cette période là
La machine linux utilisée est une tcc893x (dual cortex a9 + corpo cortex m3)
De Telechips
Donc maintenant il faut trouver si c'est Telechips qui a fait le portage Android, ou Hyundai
Et avec de la chance, en fonction de la licence, ils ont reversé les sources
A priori ce serait des apk pour a Android 4.2. Mais faut checker les permissions
Oui, développer pour Linux/Android nécessite de publier les sources quelque part, donc il faudrait trouver où Hyundai ou Telechips ont publié ces sources
je viens de récupérer le kernel3.1.1.10 mais c'est trop générique, il faudrait trouver les sources du firmware de la IONIQ basée sur ce kernel3.1.1.10.
Le lien trouvé par Chriss tout à l'heure pointe vers un lien mega.co qui n'existe plus :/
Ca c'est très prometteur !!! Pas sûr d'avoir le niveau pour hacker un android, mais si j'ai un moment j'essaierais de creuser un peu L'idée de base serait en effet de parvenir à faire un apk accepté par la voiture ! On pourrait envisager de détourner l'utilisation du bluelink je pense .....mais pas si facile s'ils ont utilisé une clé spécifique pour signer leurs apk.
Dans ce cas il faudrait trouver un moyen de rooter le système afin d'installer des apk maisons ^^
Rooter des appareils sous 4.2 est possible avec Linux:
https://m.youtube.com/watch?v=tvMwTwuTMsI
Le fait que ce soit pas Android en dernière version va nous faciliter la tâche. D'après ta vidéo il faut donc trouver comment se connecter à l'android via USB. Il y a une prise de ce type ou au moins des pins sur lesquels on pourrait raccorder une prise USB?
Si on a ça, on peut utiliser adb afin de pousser un apk permettant le Root!
Envoyé de mon Nexus 5X en utilisant Tapatalk
La prise usb sur la ioniq fera l’affaire à priori
Il faudrait y brancher un pc avec adb et voir si Android est détecté !
Quelqu'un avec une ioniq peut tester à l'occasion ?
mais il faut que l'appareil android (ioniq) accepte le debuggage USB sinon c'est mort
Oui mais il y a peut être des solutions de contournement.....à voir déjà si l'adb détecte l'android
